connection between Cisco 2950 and an Alcatel switch
Hello everybody,
I try to cascade a cisco 2950 with an alcatel switch ( with a cross cable) and then about 2 mn later the Cisco 2950 is re-booting.
I already try to put 10/half and spanning tree portfast on the cisco port used for the connection betwen the 2 switches but it's still the same...
Is someone has got an idea about this problem???
Many thanks and best regards.
Jerome
1 ACCEPTED SOLUTION
Bronze
Re: connection between Cisco 2950 and an Alcatel switch
Did you try reinstalling your IOS image or upgrading to a new one. I don't remember hearing of such a problem and IOS corruption seems to be the likely cause.
Bronze
In fact it's exactly what i do ( i put the last IOS version on this catalyst) and then everything was working well.
Many thanks and regards.
Jerome
113
