03-19-2003 05:16 AM - edited 03-02-2019 05:59 AM
I configured a last resort access to a 1710 via the Serial B port of a Sun. It works parially, as I can login to the 1710 when issue'ing tip -9600 /dev/term/b.
Although, the connection is extremely slow, and changing the console speed to 19200 doesn't change it. Any idea why ? i have the following configuration:
line con 0
logging synchronous
login local
terminal -type vt100
tranport preferred none
transport output none
thanks in advance, Karien
03-19-2003 09:07 AM
Although console speed of cisco router is typically 9600 baud, should't be that bad for access. Make sure to Set the Sun serial port speed, data bits, parity, and stop-bits to 9600-8-N-1 (the default setting) or match the settings configured on the comm server (if different)
Here is the document which talks exactly that
http://www.cisco.com/warp/public/793/access_dial/sun_comm_server.html
03-19-2003 09:30 AM
That is exactly what I configured, but apparently there is something else that makes the connection slow ..:
Any idea ?
03-19-2003 12:59 PM
You can try to eliminate any console port issues by plugging a windows console to 1710 and testing it. you can try to use serial A port on Sun (if you have it) or other sun machine to console into 1710
