Connection prob with 2550 and 2950
I have 3550-12g with one port witha routed ip 192.168.1.1. the 3550 itself ois 192.168.5.22. the por tis a 1000bt gbic. there is a 2950 attached tot his port. And 1 pc on it as a test. the 2950 gateway is 192,168,5,22 which is the 3550 switch. i can ping from the 2950 the 3550 at 5.22 or 1.1. i can alos ping from the 3550 the everything including the pc which is static at 192.168.1.15 adn the gateway is the 1.22 2950. i can not ping anything ut 1.22 th 2950 form the pc. what am i missing here. thanks
1 REPLY
Bronze
Re: Connection prob with 2550 and 2950
Please post the config and port number and describe the problem little clear. It seems like the PC is connected to 3550 and 2950 but both PCs can;t talk to each other. Is this seems like the problem
172
