Connection problem with Mica modem over on 3640
I try to connect with 56k modem but I lose the connection after one minute.
This is 3640 configuration:
username test password test
modem country mica italy
ip subnet-zero
async-bootp gateway 192.168.0.1
async-bootp dns-server 192.168.0.239
async-bootp nbns-server 192.168.0.237
isdn switch-type basic-net3
interface Loopback0
interface ethernet 0/0
ip address 192.168.0.200 255.255.255.0
interface BRI1/0
no ip address
isdn incoming-voice modem
interface BRI1/1
no ip address
interface BRI1/2
no ip address
interface BRI1/3
no ip address
interface Group-Async1
ip unnumbered Loopback0
dialer idle-timeout 600
encapsulation ppp
dialer in-band
async mode interactive
peer default ip address pool bologna
ppp authentication pap chap ms-chap
group-range 65 70
ip local pool bologna 192.168.0.201 192.168.0.210
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
ip pim bidir-enable
line con 0
line 65 70
modem InOut
autoselect ppp
login local
line aux 0
line vty 0 4
login
end
This is Debug:
01:25:07: As65 PPP: O pkt type 0x0021, datagramsize 101
01:25:07: As65 PPP: I pkt type 0xC021, datagramsize 8
01:25:07: As65 LCP: I TERMREQ [Open] id 2 len 4
01:25:07: As65 LCP: O TERMACK [Open] id 2 len 4.
01:25:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async65, changed state to down
01:25:09: As65 LCP: TIMEout: State TERMsent
01:25:09: ISDN BR1/0: VOICE_HANGUP Event: call id 0xE, bchan 0, ces 1, cause 0x10
01:25:09: ISDN BR1/0: Event: Voice hangup call to call id 0xE
01:25:09: ISDN BR1/0: process_disconnect(): call id 0xE, call type is VOICE, b_idb 0x6119A698, ces 1, cause Normal call clearing(0x1
0)
01:25:09: %ISDN-6-DISCONNECT: Interface BRI1/0:1 disconnected from 348xxxxxxx, call lasted 135 seconds
01:25:09: ISDN: get_isdn_service_state(): idb 0x6119A698 bchan 2 is_isdn 1 Not a Pri
01:25:09: CCBRI_Go Fr Host InPkgInfo (Len=13) :
01:25:09: 5 8 1 0 E 3 8 1 90 8 2 80 90
01:25:09:
01:25:09: ISDN BR1/0: TX -> INFOc sapi=0 tei=94 ns=3 nr=1 i=0x0801C94508028090
01:25:09: DISCONNECT pd = 8 callref = 0xC9
01:25:09: Cause i = 0x8090 - Normal call clearing
Re: Connection problem with Mica modem over on 3640
Above debug shows that the connection has lasted for 135 secs..
Now try to configure the following commands to configure the idle-timeout properly..
conf t
dialer-list 1 protocol ip permit
dialer-group 1
That will make the all the ip traffic as interesting so link should stay up for atleast 600 secs..If not lets get
debug dialer
debug modem csm
debug modem
debug isdn q931
In my opinion is that when you say 'login local' the default exec-timeout is 2 minutes.
This is what we use:
line 65 70
modem InOut
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
stopbits 1
flowcontrol hardware
No problems with that !!!
Edwin van Wijk
89
