connectivity problem...
We have 3640 router with NM-4 A/S serial interface module installed in it. it was working fine with 128K leased line but when we upgraded the link to 512K the router become unstable it cannot handle heavy traffic..any help
Re: connectivity problem...
Set the Bandwidth to 512
conf t --> interface serial 0 --> Bandwidth 512
Silver
you probrally are using a low speed serial card they can only handle speeds to 128K .
do a sh ver and it will show you see below , the line taht says low spped serial interface
cisco 2610 (MPC860) processor (revision 0x203) with 53248K/12288K bytes of memory.
Processor board ID JAD04170IJP (3258426822)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
4 Low-speed serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
NM cards can handle only a max bandwidth of 128 K. If you want 512 K, then you need to put a WIC card, which can take a max of 2 MB.
Cheers!!
My problem is that when i make a back to back connection with 2 2500 series routers the protocol went down after 10 secondes;however when i put no keepalive the link protocol stay up,but no input packets.
I use cisco dce dte cable ,at the dce side i play with different clock rate the problem unsolved.
Many thanks in advance.
Silver
v
100
