Console Access Problem
I am using Hyperterminal 5.1 (WinXP Pro) as console to a C827. I encounter a very annoying problem. When I hit up arrow to repeat a command, instead of the command repeating I see the following output:
^@ <Carriage Return>
My configuration is as follows:
9600 BPS
8-N-1
VT100 Emulation
All other settings are at Hyperterminal default.
Thanks in advance for any assistance!
Re: Console Access Problem
From a HyperTerm-Hater: Best of all is not to use this #$%^& product.
Nothing but misery with HyperTerm. Still it should work.
Try to change the function of the CTRL, Fn and Arrow-keys to Windows instead of Terminal keys. This option is under Connection> Settings
Goodluck
Changing the arrow keys to function as Windows keys causes the arrow keys to behave as cursor keys.
Thanks!
99
