Console cable
Where can I get a console cable for my 4000 series router?
Re: Console cable
You can probably build one yourself. Here is the document on CCO which lists the pinouts for the Cisco 4000-M, 4500-M and 4700-M console port:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis4000/4000m/4000sig/connect.htm#xtocid31796
Under the cabling guide for console & aux ports:
http://www.cisco.com/warp/public/701/14.html#consoleport
there is a link "Table of Routers with Console and AUX Ports" which will provide you the details to make your own console cable.
http://www.cisco.com/warp/public/701/14.html#table
Hope this helps.
Nash
Re: Console cable
Hey thanks for the links, but I still cant get my session up. I have a cisco console cable but i can not get my session to build up.
This is what I have http://images.andale.com/f2/115/106/3695280/1003419321089_Console_Cable_Kit.JPG
And it still is not working.
Re: Console cable
oops, nevermind.
Got everythign to work, my laptop's serial card was loose. :P
1390
