Community Member
Console management
I would like to console into any of my 30 cisco devices from anywhere on my network. Anyone have a suggested device to terminate all the console connections? It would be a device that can be placed on the network with an IP and then connect to that device and choose which device to console to. Any advice would be greatly appreciated. Thanks!
Re: Console management
A 2600 with nm-32a and octal cables would do fine - provided the cables can reach. Otherwise you may need to get a couple 2600 and small port density async card. They come in 4,8,16,and 32.
Get a 2600 with NM-32A, the necessary Octal cables (you will need 4 of them). And use the following configuration.
http://www.cisco.com/warp/public/793/access_dial/comm_server.html
The configurations are for a 2500 but its no different than the 2600. You could also use 4 2509s, if you can get it cheap off ebay.
91
