Community Member
Console port not responding
I won't be able to configure my router , cisco 3660, through console as it won't respond to the keyboard strokes. I can see all the messages in hyperterminal while it boots up, but won't be able to type anything. I have tried changing console cable as well as tried with another PC. But result is same.
Have anyone come accross such a situation?
Seetharaman.
1 REPLY
Community Member
Re: Console port not responding
This reminds me of somebody suggesting (on comp.dcom.sys.cisco) to cut the rx track of the console interface, on the router board to prevent password recovery.
If this is the problem .... well you need to fix it or replace the router, otherwise it could be an hardware failure.
278
