content engine syslog on solaris
HI There
I have a problem getting my Content Engine to syslog to cw2k lms on solaris 8. It works when i delete all the cw2k installed entry in the syslog.conf and replace it with *.debug. So my CE send the syslog to cw2k, any idea why i have to delete the cw2k specific entry and replace it with *.debug
1 ACCEPTED SOLUTION
Re: content engine syslog on solaris
It sounds like the message is coming in with an unexpected facility.
When syslogd receives a message, it checks the incoming facility and severity against entries in /etc/syslog.conf. When it finds a match, it sends the message to the destination (a local file, a remote collector, etc.) Entries follow this format:
facility.severity destination
Cisco Works adds an entry of:
local7.info /var/log/syslog_info
which means that any message with a facility EXACTLY matching local7 and a severity of info(rmational) or higher (everything except debug) will be appended to /var/log/syslog_info
*.debug will match ANY facility and ANY severity.
You should either:
1) configure the content engine to send messages using local7 facility, and use the default CW2k entry in /etc/syslog.conf
or
2) determine the facility used by the content engine and add an explicit line in the /etc/syslog.conf for those message types, keeping the cw2k entry as well, like this:
local5.info /var/log/syslog_info (replace "local5" with the appropriate facility from the C.E.)
To discover the facility from the C.E., you can set up a temporary syslog server on a PC using a free syslog server, like Kiwi Syslog (http://www.kiwisyslog.com). Point the content engine to the PC and generate a message, then look at the "priority" column to find the facility.
1 REPLY
You should either:
or
112
