Community Member
Continuous 2950 management VLAN problem
According to all the Cisco instructions you are able to change the management VLAN on the 2950 from the default(1) to another number. I want my management VLAN to be 10. My problem is that every time 10 is set up and I bring up VLAN 1 the switch locks up and VLAN 10 will be shut down. It would seem strange that if you designate another VLAN as the management you can never bring up 1 again. Is it a bug where VLAN1 has to remain down. It can't be that you can only have one active VLAn running! I have configured 10 with an IP and have also done the following clustering commands:
cluster enable management 4
cluster management-vlan 10
cluster run
I don't want any memebrs no none were assigned, thus I don't need the timer or hold time commands. HELP...
Re: Continuous 2950 management VLAN problem
It's not a bug. On a CAt2950/XL switches you can have only one VLAN interface up and up at any point in time. It's a layer 2 switch only and having multiple VLAN interfaces up/up does not give any benefit
Community Member
So all my other VLAN interfaces have to be administratively down for this to work.
Community Member
Yes, as mentioned before, you can only have one management VLAN interface up at a time but you can configure multiple ports to be in multiple VLANs.
In the config below I have created Interface VLAN 2 and have placed additional ports on the switch into that VLAN. The remaining ports are all on the default VLAN 1. We have three ports doing trunking because this is a distribution switch and we have the router off one of the ports and an access switches downstream the other ports.
You will also notice that the default VLAN 1 is shutdown. There is no way to change that.
scms010#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname scms010
logging buffered 8192 debugging
no logging console
enable secret 5 $1$VnCI$E3UCMOWZdAe2sR4yegk7C1
ip subnet-zero
ip domain-name infosys.monterey
ip name-server 172.25.4.8
cluster enable Distribution 0
cluster member 1 mac-address 0008.a3c1.4540
cluster member 2 mac-address 0008.a3c0.7fc0
cluster discovery hop-count 1
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip address
no ip directed-broadcast
ip nat outside
shutdown
interface VLAN2
ip address 172.25.130.220 255.255.255.0
ip nat outside
ip default-gateway 172.25.130.200
ip nat inside source list 199 interface VLAN2 overload
access-list 199 dynamic Cluster-NAT permit ip any any
snmp-server engineID local 0000000902000008E3FC5900
Community Member
What the other poster said is true. But it is different than saying that you cannot have multiple VLANs on your switch. You CAN have multiple VLANs on your switch but you will most likely have to do some sort of trunking, either ISL or 802.1q.
You can have only ONE management VLAN up at a given time, but you can still put ports 1-10 in VLAN1 and ports 11-24 in your VLAN 10.
Does this make sense?
124
