SAP
Convert ATM To Frame & Vice Versa
Hi :)
let me tell you a little about my situation. Palo Alto, CA is connected to Philly with ATM. Philly has remote sites and the line is frame-relay. We are now having the provider setup dlci/pvc from the remote sites to palo alto, ca and activate only if the site between philly and remote sites go down.
What is the command to convert atm into frame and vise versa?
Thanks!! :)
1 ACCEPTED SOLUTION
Re: Convert ATM To Frame & Vice Versa
Looks like you are doing ATM to FR IWF. There is no such command convert atm into frame. Carrier will do the translation between ATM PVC and the Frame-Relay DLCI. You will config the ATM PVC and Frame PVC the normal way.
Check the URL for detail:
http://www.cisco.com/en/US/tech/tk39/tk53/technologies_configuration_example09186a0080094588.shtml
Bessie
SAP
Thanks! but, i'm a little confuse...i have a ATM Mux of 6Mb to Philly...So, i want the pvc's/dlci to link to the ATM Mux, but like i mentioned before the remote sites are frame-relay.
Bessie
SAP
perfect!!!!!...that makes my life a whole lot easier :)
here's kisses and hugs :)
92
