Community Member
Cookies Problem
I´ve installed CDone, patches and RME for RWMS and then I´ve tried to see the screen (http://ip:1741)and It doesn´t appear anything in the left side. I can see a question mark in Cookies and It seems to be looking for something. Java is enabled.
The installation was made withouth problems.
What can I do?
Thank you.
Bronze
Re: Cookies Problem
Cookie has a question mark usually means the JRunProxyServer process is down. Do "...\CSCOpx\bin]pdshow" to verify and use "pdexec JRunProxyServer" to bring it back.
Community Member
Re: Cookies Problem
Thank you, this answer resolve my problem. My new problem is that I have to bring back JRunProxyServer process every time I restart mi Server and I have to do it twice because the first time it appears time over.
I don´t know if this is a Bug or if I can download a patch for this issue.
Bronze
Re: Cookies Problem
It's always good practise to include CD1(or Common Services)/RME version and server OS. However, I searched thru and found no bugs match your scenario.
I suggest reinstall all CW, if it's Windows machine, make sure it does not join any domain, and always use local admin to install, etc. Also make sure no other applicantions on same server to avoid port conflict.
111
