04-09-2002 10:47 AM - edited 03-01-2019 09:13 PM
I'm trying to copy a .bin file, from my tftp server, to a 2924 switch in my network.
I get the following error when trying to perform a "copy tftp flash"....
copy to or from flash not implemented
Any thoughts on this?? I've never seen this one before.
Thank-you.
04-09-2002 11:23 AM
not sure what filesystem you have available on this device, but could you try to replace the keyword 'flash' with 'slot0:' or s'lot1:' or 'bootflash:'
04-09-2002 11:28 AM
Hi. The current file is c2900xl-hs-mz-112.8-SA5
When I perform a "copy tftp ?", I see the following for options..
WORD
rcp
running-config
tftp
Thanks for your help.
04-09-2002 11:07 PM
There are many possible reasons why you can not copy the image on the flash.
Is your switch a 4MB switch or 8 MB Switch?
If you are planning to upgrade your switch you latest version, follow the procedure given in this document.
The 2900XL switches doesn't behave like other routers in upgrading procedure.
Here is the document:
http://www.cisco.com/warp/public/473/36.shtml
Let me know if this link doesn't work for you.
