09-09-2003 03:54 PM - edited 03-02-2019 10:13 AM
I have a cisco4006 with supervisor engine III.
I have two firewalls.
I want to realize load-balanced between two firewalls.whether it can realize,or not?
09-15-2003 12:11 PM
Not clear what you are asking. If you are asking whether switch can recognize the difference between active and standby firewalls, answer is yes.
09-16-2003 05:08 AM
hello!
at first, thank you!
I have a catalyst 4006 with a supervisor engine III.
I have two identical firewalls with fastethernet ports.they have connect with catalyst 4006.
I have apply two different 100M Internet connections.they have connect with two firewalls
users(ABOUT ONE thousand,in different vlans),who connect to catalyst 4006, want to browse information at internet .
I,as a network manager,want that two firewalls work at same time and load balancing.
please tell me whether catalyst 4006 with a supervisor
engine III can fulfill this work or not?
if can,please tell me how fulfill this work.what are prerequisite?
09-16-2003 10:54 AM
I haven't dealt with this for a while, things are changing all the time, but the principles should be the same. So the answer doesn't really depend on the 4006, but on your firewalls. First of all the firewalls need to maintain state information that is accurate and real time. Lets say a packet goes out fw1 and comes back in fw2, if fw2 doesn't have state info on the packet, it drops it. Therefore, some device need to maintain a table on which session came thru which fw and makes sure that the packet returns thru same fw. This is pretty much what fw load balancers do, like alteon, rad and cisco has one also. Otherwise you pretty much have to have one in active and one in standby. Hope that makes sense.
09-16-2003 05:37 PM
IOS Supports firewall load balancing, this is part of SLB Feature. State sync is not necessary between firewalls with this technique.
Unfortunately Cat 4006 with SupIII does not support this feature as of now.
Hope this helps,
Subba Rao
09-16-2003 08:00 PM
thank you!!!
09-16-2003 09:47 PM
thank you!!
I am ready to get CCNP.
please give me some advices.
In china,many people get CCNP certification by reciting examination questions.
I think that it is wrong.I am doing experience and looking through CCNP materials.
thank you
bye
your sincere friend
my email:syzbw@public.cs.hn.cn
