Could not connect to remote router
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname --moderator edit--
enable secret 5 --moderator edit--
clock timezone EST -4
ip subnet-zero
interface Ethernet0/0
ip address 10.1.100.18 255.255.0.0
interface Serial0/0
ip address 192.168.1.18 255.255.255.252
service-module t1 clock source internal
service-module t1 timeslots 1-8
router eigrp 10
redistribute connected
redistribute static
network 10.1.0.0
network 192.168.1.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
line con 0
password --moderator edit--
login
transport input none
line aux 0
line vty 0 4
login
no scheduler allocate
end
This config is over SF serial point to point 512k.
Silver
Re: Could not connect to remote router
what does a sh int s0/0 and a sh service-module look like ?
This is serial0/0:
#show interface serial0/0
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 192.100.100.16/16
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output 00:00:01, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
314 input errors, 134 CRC, 103 frame, 0 overrun, 0 ignored, 77 abort
31864 packets output, 2002090 bytes, 0 underruns
0 output errors, 0 collisions, 8371 interface resets
8 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
This is the service-module:
: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to down
Module type is T1/fractional
Hardware revision is 0.104, Software revision is 0.2,
Image checksum is 0xED22BEC5, Protocol revision is 0.1
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is internal,
Fraction has 8 timeslots (64 Kbits/sec each), Net bandwidth is 512 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 1d11h
loss of signal : 1, last occurred 1d10h
loss of frame : 2, last occurred 1d10h
AIS alarm : 0,
Remote alarm : 3, last occurred 09:36:51
Module access errors : 0,
Total Data (last 96 15 minute intervals):
7 Line Code Violations, 52 Path Code Violations
217 Slip Secs, 2 Fr Loss Secs, 1 Line Err Secs, 1 Degraded Mins
216 Errored Secs, 1 Bursty Err Secs, 2 Severely Err Secs, 0 Unavail Secs
Data in current interval (372 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
1d11h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state
to up 4 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Silver
The ip address in your original config does not match what is pasted in on your latest port. What is the ip address ?
what does a sh cdp nei s0/0 det show?
what does a sh ip route to the ip address of the remote side of the circuit show ?
I see your line bounced during the capture of the post and some slips in your sh service-mod.
who provides clock ? you or your service provider , if you then make sure that one csu is set for internal and the other csu is set to get clock from the network .
slips & aborts are usually a clocking problem
What do you mean by slips & aborts? I see that the router keeps bringing up and down the serial int. I change the clock to line and reloaded the router and to my surprise it did not save the configuration. It prompt me if I wanted to enter initial configuration and the prompt says ROUTER>. Any help.
Silver
If you saved your config it should be in NVRAM do a sh start it will show you the saved config, then do a copy start run , the change the config register to 0x2102
router#(config)config-reg 0x2102
When it prompts you to save the config say no
aborts and slips have to do with clocking . paste in the config from the remote end .
100
