HI, I have a 6500 switch, It?s working with CatOS 8.3(7), do you know a command to clear counters reported by snmp, I only know the command clear count mod/pto and the output show me:
This command will reset MAC and port counters reported by the CLI for port(s) 2/12.
Counters reported by SNMP will not be affected.
Do you want to continue (y/n) [n]?
So it?s possible "affected counters reported by snmp" using some command
thans and best regards
