10-02-2002 09:28 AM - edited 03-02-2019 01:47 AM
What does this mean "CPU Interface 0 storage notify failed on queue 1"
10-02-2002 05:17 PM
I'm assuming you are seeing this on a 2900/3500XL switch..If so, do a sh post and see if the post test fails. If it does, the switch needs to be replaced
10-03-2002 01:17 AM
Thanks for your reply. i keep getting that message, could you explain me the meaning of it
#sh post
Passed
#sh vers
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 30-Apr-01 07:51 by devgoyal
Image text-base: 0x00003000, data-base: 0x003331F4
ROM: Bootstrap program is C3500XL boot loader
lx3524pt uptime is 16 hours, 52 minutes
System returned to ROM by reload
System image file is "flash:c3500XL-c3h2s-mz.120-5.3.WC.1.bin"
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID FAB0523V0YF, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:06:53:0F:4D:40
Motherboard assembly number: 73-3904-11
Power supply part number: 34-0851-02
Motherboard serial number: FAB052321E0
Power supply serial number: PHI050906WB
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3524-XL-EN
System serial number: FAB0523V0YF
Configuration register is 0xF
12-03-2002 09:55 AM
I would be intrested in the aswer to because post does not fail but i allso receive a lot of those debug messages but evrything seems to be working ?
RGZ
Tom
12-04-2002 05:26 AM
Those messages are displayed when 'debug cpu-interface' is enabled.
At one time, the error message indicated that the CPU tried to send a packet to a port, and the port did not accept it. This is still true on systems that do not support ISL or 802.1q (the C2908XL, C2916M-XL, and the old models of the C2924XL and C2924C-XL). This can happen if the switch receives a burst of traffic and the traffic exceeds the bandwidth of the port or the switch.
On systems that support ISL and 802.1q (all the currently orderable C2900XL and C3500XL boxes), this "error" message is normal and will happen almost every time the CPU tries to send a packet to a port.
12-04-2002 07:17 AM
I am using trunking (802.1q to 2611) so this could be the cause, maybe the topic starter could allso verify that he is using trunking also.
Is this classifieable as a bug because evrything works fine. There does not seem to be any information available on this issue, how dit you find out about this ?
Thanx for your helpfull info.
Tom
12-05-2002 12:10 AM
First of all, those messages only appear if a specific debug is enabled. Furthermore, those debugs are not really useful for customers and have only been used for specific bugs debugging. Now, it is true that those messages are displayed eventhough there are no errors, so it can be considered a bug (cosmetic).
12-05-2002 11:23 PM
Thanx, thats what i suspected but could not get confirmed, as i told there don't seem to be any issue with my switch, but it allways is a bit concerning to me when i am not able to explain strange messages.
Thanx
