CPU Load balancing
I have a 5500 and want to add another RSM to share the CPU load. I do not have any extra slots on my 5500. How can I add another 5500 with an RSM to share the load of the first one (router load only). I want to leave all my ports connected to my first 5500 switch but want to share the rsm load.
ANy help would be appreciated.
thanks
Re: CPU Load balancing
Has anyone ever done this?
Bronze
Network devices generally don't work this way. For all intents and purposes, "load sharing" the CPU usage of 2 or more devices entails dividing the traffic load between them.
Have you enabled CEF and MLS?
If not I would recommend enabling both as it will make a big difference to the RSM CPU load.
Let me know if you require more information and I will send you some links.
Peter
I have enabled CEF (not mls.. i looked into that one as well.. cant remember off hand why i did not implement that ) but I would appreciate if you can send me those links.
thanks
This document has good information. If you have access-lists, read the section on access-list as some options prevent MLS working on the interface.
http://www.cisco.com/en/US/customer/products/hw/switches/ps679/products_configuration_guide_chapter09186a008007ee53.html
Hope that helps.
195
