CPU load high with "Calhoun LED Proc"
hi,
We have a lot of 2950-G with 25% to 30% cpu load.
I found the "Calhoun LED Proc" with 9 %.
Any one know what the Calhoun LED Proc means ?
attached the show process cpu.
best regards.
fred.
OFCE3-3F-20#show proc cpu
CPU utilization for five seconds: 26%/8%; one minute: 26%; five minutes: 26%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 3524 53004 66 0.00% 0.00% 0.00% 0 Load Meter
3 212 87 2436 0.00% 0.00% 0.00% 0 SpanTree Helper
4 82952 26952 3077 0.00% 0.03% 0.00% 0 Check heaps
5 876 1277 685 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 52 5 10400 0.00% 0.00% 0.00% 0 Entity MIB API
8 2724 52996 51 0.00% 0.00% 0.00% 0 HC Counter Timer
9 229676 364064 630 0.08% 0.10% 0.08% 0 ARP Input
10 14896 10801 1379 0.00% 0.00% 0.00% 0 Net Input
11 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
12 83520 272085 306 0.08% 0.02% 0.00% 0 Net Background
13 828 45143 18 0.00% 0.00% 0.00% 0 Logger
14 16300 264313 61 0.00% 0.00% 0.00% 0 TTY Background
15 126512 264325 478 0.08% 0.03% 0.02% 0 Per-Second Jobs
16 41148 53004 776 0.00% 0.00% 0.00% 0 Compute load avg
17 47172 4418 10677 0.00% 0.01% 0.00% 0 Per-minute Jobs
18 0 5 0 0.00% 0.00% 0.00% 0 AggMgr Process
19 0 2 0 0.00% 0.00% 0.00% 0 Calhoun Storm Co
20 30434276 5762835 5281 9.66% 9.75% 9.77% 0 Calhoun LED Proc
21 4159148 518491 8021 1.39% 1.38% 1.39% 0 Calhoun Statisti
22 731800 1281056 571 0.49% 0.32% 0.31% 0 HMATM Learn proc
23 503968 5183419 97 0.08% 0.12% 0.10% 0 CalhounPM
24 8832548 1280801 6896 0.81% 0.51% 0.48% 0 Link Status Proc
25 0 1 0 0.00% 0.00% 0.00% 0 CalhounInsIpopti
26 51048 42559 1199 0.00% 0.01% 0.00% 0 CDP Protocol
27 18521144 13754519 1346 4.58% 4.58% 4.62% 0 IP Input
28 7824 17816 439 0.00% 0.00% 0.00% 0 DTP Protocol
29 724 26505 27 0.00% 0.00% 0.00% 0 Ethchnl
30 536 921 581 0.00% 0.00% 0.00% 0 VLAN Manager
31 0 2 0 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
32 520 1097 474 0.00% 0.00% 0.00% 0 VMATM Callback
33 825976 446341 1850 0.08% 0.14% 0.13% 0 Spanning Tree
34 21548 265082 81 0.00% 0.00% 0.00% 0 UDLD
35 132 4419 29 0.00% 0.00% 0.00% 0 Port-Security
36 508 170 2988 0.00% 0.22% 0.10% 1 Virtual Exec
37 0 1 0 0.00% 0.00% 0.00% 0 HTTP Timer
38 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
39 1384 9959 138 0.00% 0.01% 0.00% 0 TCP Timer
40 96 51 1882 0.00% 0.00% 0.00% 0 TCP Protocols
41 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
42 584 991 589 0.00% 0.00% 0.00% 0 L2MM
43 52152 152687 341 0.08% 0.02% 0.00% 0 MRD
44 46424 59533 779 0.00% 0.00% 0.00% 0 IGMPSN
45 738240 152145 4852 0.00% 0.04% 0.05% 0 IGMP Snooping Pr
46 58188 62566 930 0.00% 0.00% 0.00% 0 IGMP Snooping Re
47 141016 163007 865 0.00% 0.04% 0.03% 0 IP Multicast Dat
48 8 2 4000 0.00% 0.00% 0.00% 0 L2TRACE SERVER
49 156 3316 47 0.00% 0.00% 0.00% 0 Cluster L2
50 1104 26504 41 0.00% 0.00% 0.00% 0 Cluster RARP
51 3064 34765 88 0.00% 0.00% 0.00% 0 Cluster Base
54 0 3 0 0.00% 0.00% 0.00% 0 Router Autoconf
55 176 42 4190 0.00% 0.00% 0.00% 0 Syslog Traps
56 0 2 0 0.00% 0.00% 0.00% 0 VTPMIB EDIT BUFF
57 74484 1476622 50 0.08% 0.03% 0.00% 0 PM Callback
58 16 12 1333 0.00% 0.00% 0.00% 0 VTP Trap Process
59 0 1 0 0.00% 0.00% 0.00% 0 l2vlanifmib
61 9048 264329 34 0.00% 0.00% 0.00% 0 Calhoun EnvMon P
62 0 2 0 0.00% 0.00% 0.00% 0 STP STACK TOPOLO
63 0 2 0 0.00% 0.00% 0.00% 0 STP FAST TRANSIT
64 0 2 0 0.00% 0.00% 0.00% 0 STP STACK TOPOLO
65 0 2 0 0.00% 0.00% 0.00% 0 CSRT RAPID TRANS
67 0 3 0 0.00% 0.00% 0.00% 0 SNMP Timers
68 4780 6247 765 0.00% 0.00% 0.00% 0 IP SNMP
69 2056 3048 674 0.00% 0.00% 0.00% 0 PDU DISPATCHER
70 8916 2991 2980 0.08% 0.00% 0.00% 0 SNMP ENGINE
71 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
72 252 88 2863 0.00% 0.00% 0.00% 0 SNMP Traps
73 13920 268254 51 0.00% 0.00% 0.00% 0 NTP
OFCE3-3F-20#
OFCE3-3F-20#
1 REPLY
Re: CPU load high with "Calhoun LED Proc"
I have the exact same issue and was also wondering the same thing. Only see it on the G switch and not on out C switches.
Found this on cisco website: They have a baseline that shows same 30% cpu utilization on the G switch even though the C switches that we have run at 4%
_______
The common observation is that the CPU utilization output for the show processes cpu command on the 2900XL/3500XL switch shows a fairly high value when the switch is idle and has no active ports. When viewing the output of the show processes cpu command, the highest percentage processes are Port Status Process and Led Control Process. It is normal behavior for these processes to be a high percentage of the total CPU utilization.
As clear as mud really !
378
