CPU load Problem
I am using 2950, CPU load of the switch is often increase upto 80 and 90%.
I attached a file which contain the CPU Services detail..
Re: CPU load Problem
do you have a lot of broadcast traffic?
Regards, Martin
No, i dont have that much traffic which increase the CPU load to 90 %.
do you have multicast traffic? It seems that quite some portion comes from IGMP snooping.
From
http://www.cisco.com/en/US/products/ps6552/products_white_paper09186a00800d6b5e.shtml#xtocid17
"Because IGMP control messages are sent as multicast packets, they are indistinguishable from multicast data at Layer 2. A switch running IGMP Snooping must examine every multicast data packet to determine if it contains any pertinent IGMP control information. IGMP Snooping implemented on a low-end switch with a slow CPU could have a severe performance impact when data is sent at high rates. The solution is to implement IGMP Snooping on high-end switches with special application-specific integrated circuits (ASICs) that can perform the IGMP checks in hardware. CGMP is a better option for low-end switches without special hardware."
So try to turn off IGMP snooping and rather use CGMP if required.
Regards, Martin
155
