09-24-2002 12:38 PM - edited 03-02-2019 01:36 AM
In troubleshooting connectivity on a switch port, a 'show int' command shows that the port is getting CRC errors. What exactly is a CRC error and what causes them?
09-24-2002 02:20 PM
CRC is Cyclic Redundancy Check. Most of our switches use the store-and-forward switching method and so the switch copies the entire frame into its onboard buffers and computes the cyclic redundancy check (CRC). The frame is discarded if it contains a CRC error or if it is a runt (less than 64 bytes, including the CRC) or a giant (more than 1518 bytes, including the CRC). If the frame is discarded, the counter is incremented. Check for any duplex mismatch, bad cable/NIC. Also the following page should be useful
09-27-2002 02:38 AM
For this CRC errors .. u can try replacing u r server network cards... actually there r situations where faulty network cards created this kind of errors....
sol: check the port which gives crc errors and change the NIC card for those systems and then monitor...
09-27-2002 02:46 AM
sorry i forgot to mention onething....
first u try to upgrade the code of the NIC cards if it is available r else try to reload the drivers again for that servers .. else in the worst if still rpob persists try to change the cards....
11-13-2002 07:49 PM
CRC errors are generally caused by either bad cable or duplex mismatch. You can copy the "show int" output to CIsco's tool, and it will give you an explaination
