Webcast-Catalyst9k
Create Basline in Netsys setup
Can anyone please help me with my Netsys problem ?.
When I try to create a Baseline and I follow the Online Help and checkmark the "Create Baseline" box the Help says that if I should type my Username and Password but where do I find this. What Install Directory should I thoose ?.
Finally when I press "Apply" the server tells me that he are not able to communicate with Netsys host. Telnet session aborted.
Normaly when I logon to the server I use the "Puttey application" but when Netsys try to logon it use a telnet to the localhost ???.
Red
Re: Create Basline in Netsys setup
Seems to me that you are trying to use Netsys from
a remote machine. If that is the case, please try
using it on the server itself
No it's on the server it self. The netsys_debug.log
tells that:
Telnetting to localhost..
Err_Handler: problem connecting to "localhost", port 23: Connection refused 9
Blue
To create the baseline, use the Wizards in Netsys, it's much more easy to use that way.
Thanks but where do I find this Wizard.
Blue
Launch Netsys->File->New Baseline->Wizard
The problem is that I'm not able to start Netsys. When I will launch it I got a message that says "Netsys report have not been started yet" and when I push the buttom for detail it says "Schedule Netsys report generation from Resource Manager Essentials>Administration>Configuration Management>General Setup" and its here I'm running in to trouble when I trying to create a new Baseline.
150
