You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Creating Sub interfaces for vlan routing
Hi When I try and create a sub interface on a 2620 router on Fast ethernet 0/0 I get the following
Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q, or ISL VLAN
I cant set any encapsulation on the sub interface at all. Even after I get that message.
Any ideas???
  • Other Network Infrastructure Subjects
Re: Creating Sub interfaces for vlan routing
What software version are you running? Look at the following page for config example and software requirement
http://www.cisco.com/warp/public/473/50.shtml#Table2
Can you please tell what software version and the feature set and can you please paste the whole message.
Here is the very good link
http://www.cisco.com/warp/customer/473/50.shtml
Hope this helps
Thanks for your help.. I will port the code version
it seems to me that you can't configure the ip address before estabilish the encapsulation, so put the encapsulation first and after that try the ip address..
You will also need a version of IOS which supports this feature, I had this same problem last week and I had to upgrade to IP Plus.
John
242
