cross reference of commands between Cat 2950 & Cat 4000
I just had a rude awakening when I started "playing" with a Cat 2950 and realized that its commands are completely different from the Cats 5500, 6500 or 2980. Does anyone know of a doc with cross reference between the commands on Cat 2950 & the "traditional" switches (such as Cats 5500, 6500 or 2980)? Also, the Cat 2950 looks and feels more like a router than a switch, at least as far as the commands are concerned. What was a rhyme or reason for Cisco to do that?
Thanks.
_ Alex
1 REPLY
Re: cross reference of commands between Cat 2950 & Cat 4000
Here's a doc that should help between the CatOS and IOS command syntax.
http://www.cisco.com/warp/customer/473/101.html#catosmatrix
118
