10-23-2003 04:27 AM - edited 03-02-2019 11:12 AM
How can I upgrade the CSM WS-X6066-SLB-APC (now 3.2.0(28)) to 3.2.1 ?
I cant find the command "upgrade".
The new configuration guide describe this process with the "upgrade" command but, I can´t find the "upgrade" command in the new command reference and CSM self!?!?
Sven
Solved! Go to Solution.
10-29-2003 10:58 AM
You would have to load the image from the supervisor engine to the CSM using the command
CSM> upgrade
Make sure you are in the right mode to use the command.
Take a look at this document for details.
10-29-2003 10:58 AM
CSM> upgrade
