Community Member
css problem
www.xxxxx.co.uk points to 19x.244.202.21
www.yyyyy.com points to 19x.244.202.21 as well
the address 19x.244.202.21 maps to 192.168.214.8 internally
192.168.214.8 is a Cisco CSS which spreads load between 4 boxes accordingly
these boxes live on 192.168.6.0/24
This is the problem: since there's no host-header checking on the content switch, anything that is destined for 19x.244.202.21 (from the outside) will end on on the same IP as galagames.co.uk
*the same 192.168.6.0/24 IP
this means that we can't have another SSL cert on that address (because galagames.co.uk) is already there, because the host header is itself encypted with https
we need to find a way of sending traffing to another address, based solely on host-header
does that make sense!?
"gw01-lastmin"..."gw04-lastmin" and have it work by host header. but i dont have a clue how
Here is the config of CSS
!*************************** GLOBAL ***************************
restrict ftp
ip opportunistic all
ip redundancy
snmp auth-traps
snmp trap-host 192.168.216.14 public
snmp trap-host 192.168.216.19 public
snmp trap-host 10.171.255.11 public
snmp trap-host 10.171.255.62 public
ip route 0.0.0.0 0.0.0.0 192.168.214.1 1
ip route 192.168.213.0 255.255.255.0 192.168.216.40 1
!************************* INTERFACE *************************
interface ethernet-1
redundancy-phy
bridge vlan 10
phy 100Mbits-FD
interface ethernet-2
bridge vlan 20
redundancy-phy
phy 100Mbits-FD
interface ethernet-8
phy 100Mbits-FD
!************************** CIRCUIT **************************
circuit VLAN1
ip address 192.168.214.34 255.255.255.240
redundancy-protocol
circuit VLAN10
redundancy
circuit VLAN20
redundancy
ip address 192.168.216.33 255.255.255.0
!************************** SERVICE **************************
service asd
service g01-games
service gw01-bingo
keepalive port 80
keepalive type http
keepalive uri "/css-check.jsp"
active
service gw01-casino
keepalive type http
ip address 192.168.216.2
keepalive port 80
service gw01-games
ip address 192.168.216.1
keepalive port 80
keepalive type http
active
service gw02-bingo
ip address 192.168.216.8
keepalive port 80
keepalive type http
active
service gw02-casino
ip address 192.168.216.7
keepalive port 80
keepalive type http
active
service gw02-games
keepalive port 80
keepalive type http
active
service gw03-bingo
ip address 192.168.216.13
keepalive port 80
keepalive type http
active
service gw03-casino
ip address 192.168.216.12
keepalive port 80
keepalive type http
active
service gw03-games
ip address 192.168.216.11
keepalive port 80
keepalive type http
active
service gw04-bingo
ip address 192.168.216.18
keepalive port 80
keepalive type http
active
service gw04-casino
keepalive type http
ip address 192.168.216.17
keepalive port 80
active
service gw04-games
ip address 192.168.216.16
keepalive port 80
keepalive type http
active
owner gala_leisure
content L4_rule_port443_bingo
add service gw01-bingo
add service gw02-bingo
add service gw03-bingo
add service gw04-bingo
protocol tcp
port 443
vip address 192.168.214.10
advanced-balance sticky-srcip-dstport
active
content L4_rule_port443_casino
add service gw01-casino
add service gw02-casino
add service gw03-casino
add service gw04-casino
protocol tcp
port 443
vip address 192.168.214.9
active
content L4_rule_port443_games
add service gw01-games
add service gw02-games
add service gw03-games
add service gw04-games
protocol tcp
port 443
vip address 192.168.214.8
balance leastconn
active
content L4_rule_port80_bingo
protocol tcp
port 80
balance leastconn
active
content L4_rule_port80_casino
protocol tcp
port 80
balance leastconn
active
content L4_rule_port80_games
protocol tcp
port 80
balance leastconn
active
!*************************** GROUP ***************************
group SOURCE_NAT
!**************************** ACL ****************************
acl 2
clause 30 permit any any destination any
apply circuit-(VLAN10)
apply circuit-(VLAN20)
clause 10 permit any any destination any sourcegroup SOURCE_NAT
acl 1
clause 20 permit any any destination any
apply circuit-(VLAN1)
1 REPLY
Bronze
Re: css problem
Shashank,
If I understand your question correctly, you can terminate the ssl connections on a ssl module in the CSS (or on an external SCA), which will allow the CSS to match a content rule based on header information. If required, the CSS can also re-encrypt the traffic towards the back end servers. You can find more configuration information here:
http://cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080157875.html
~Zach
159
