Community Member
Custom Queuing on Ethernet Interface
I have a 1605R router connected to Cable Internet Service. I want to allocate\guarantee some badnwidth to traffic coming from specific internal IPs, 192.168.101.3 and 192.168.101.4.
These IP are being NAT to Public IPs using one-one static translation.
I created access-lists
"access-list 110 permit ip host 192.168.101.3 any
access-list 110 permit ip host 192.168.101.4 any
And associated these access list with Custom Queue Lists.
Ethernet0 is connected to Internet and Ethernet1 is connected to Internal network.
My question is
1. Where should the Custom List be applied, Ethernet 0 or Ethernet 1 ?
2. If it should be applied to Ethernet0, then should i modify the Access-list statements to replace the "Internal IPs" with their corresponding "Public Mapped IPs" ? As by the time the Custom-List would be evaluated the Source IP would have been changed by NAT ?
Thanx \\ Naman
Community Member
Re: Custom Queuing on Ethernet Interface
As per your situation , you will be configuring
IP nat inside in e1
and
IP nat outside in e0
when the packet leaves e1 it will be replaced with global IP address, Hence you can apply the accesslist in internal
Community Member
you mean
"when the packet leaves "e0", and not "e1" as you mentioned, as e0 is the outside interface" ? And any packet going out of e0 will have global address.
I guess i want to clarify if
Custom Priority lists are applied to the outgoing interface ?
OR
Custom Priority lists are applied to the incoming interface ?
80
