CW2000 and CDP cause 3662 Router crash???
The 3662 crash after the CW2000 connect to network and enable CDP at the fastethernet port~
The system return error messages below:
00:34:12: %SYS-2-WATCHDOG: Process aborted on watchdog timeout, process = IP SNM
P.
-Traceback= 602DCE8C 602E0948 602D8C7C 604403F0 60440C48 6043C31C 6043B664 6063C
1B4 6063FB30 60631EC4 6063AA04 6063A970 6064EBEC 60384F08 602B1BA4 602B1B90
Queued messages:
No fault history 0xFFFFFFFF. Need 11.1 (2) or higher ROM
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x61916bc0
PC = 0x602da9c0, Cause = 0x20, Status Reg = 0x34018002
is this really cause but CW2000?
The running IOS is c3660-js-mz.120-7.T.bin
Best regrads~
ZiXi Wei
Blue
Re: CW2000 and CDP cause 3662 Router crash???
Traceback decode points to the bug CSCdr74195 which is related to the IOS and not with CW2000.
But there is no HSRP configured at the crashed device~
Is the BUG means that the CW2000 device to check if the router is running HSRP and cause router crash?~
Blue
Don't know but you can use: https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl if you have the sh stack output fromt his crash ti analyze.
85
