CW2000 device discovery using SNMP
I have CW2K in Win2K installed. I have noticed that the routers at the other end are not being discovered by CW2K even though all the devices has SNMP configured.
Only the devices configured to run CDP are discovered.
How can I make the devices to be discovered over WAN without configuring CDP ?
Blue
Re: CW2000 device discovery using SNMP
Add them as seed devices in CW2K.
I have already defined the central router as seed device. Still, only the branch routers with CDP are discovered.
You will have to add every router that does not have CDP configured to the seed list in Server Configuration->Setup->ANI Server Admin->Discovery Settings
and they will only appear in the Unconnected View as standalone routers.
Without CDP you do not have any options.
If CDP is turned on everywhere except for the WAN LINKS, then you should see separate networks on your Layer 2 View.
85
