11-12-2003 07:19 PM - edited 03-02-2019 11:40 AM
I have a CW2000 Windows Server with the LMS package installed. My local routers have CDP and SNMP configured and all features in CW work great for these routers. Eight of the eleven local routers have serial T1 connections to another Cisco router. For testing I would like to manage a couple of routers on the other side of one of the T1 circuits. For example, my local router B is working fine with CW but I would like to manage router F on the other end of the T1 circuit connected to router B. I also have router G on the same LAN as router F and would like to manage that router in CW as I do with router B.
My question is what do I need to configure on the CW LMS server so that I can manage the remote routers? I know the SNMP settings must be set, but does CDP need to be configured?
Thanks for any help.
Jeff
Solved! Go to Solution.
11-13-2003 06:27 AM
Setup CDP on them or add them as seed devices.
11-13-2003 06:27 AM
