CW2000 for routed WANs and Tivoli integration
I understand that Cisco Works 2000 for Routed WANs' comes with a Tivoli Netview integration utility. I also understand that this utility is located on CD One.
I cannot find this utility on the WIndows NT CD and I have no documentation that discusses this subject. Is the utility on the Solaris CD?
I would be grateful for any help.
Thanks.
Re: CW2000 for routed WANs and Tivoli integration
When you setup software from CD-ONE you are presented a menu where you select the kind of software to install. One option is integration utility. When you select that one, you will be asked in another menu which integration adapter precisely you want. Tivoli Netview should be one of the options.
Blue
See the section 'Integrating with Third-Party Vendors' at:http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/5steditn/use_view/ug_ch2.htm for details.
118
