CW2000 Hangs while opening Device selection View
I run CW2000 with RME 2.2 on Solaris 2.6 on the same Server as OP-OV NNM.
while opening a task who requires the selection of some Devices the Browser hangs (with no Error message) while loading the Device List.
this Problem does not accure after reboot of the machine, but after a few Days.
i'm searching for the trigger who starts the Error now. Any Hints?
thanks Phil
Blue
Re: CW2000 Hangs while opening Device selection View
Same problem with both IE and Netscape?. RME 2.2 is very old now, you should consider moving to RME 3.4 which is the latest.
Yes, same Problem, even on the NMS Server itself. I also thied all Versions of Java, with no success. I know, that 2.2 is very old, but it is not sure yet if the Cusomer will resume the Contract in Sommer...
Of corse we will upgrade if the Contract goes on.
I found out now, that i can read my Data (configs, inventory...) shutting the CSCS Demons down and up using dmgtd stop/start.
the System works fine then for a few days.
thanks Phil
85
