CW2000 on UNIX dual CPU system
f.iversen
Hei
I have installed CiscoWorks 5th Edition on a UNIX system with dual CPU and I did not get any errors but there are several functions that I cant run. I think that I somewhere for long time ago saw a guideline how to do such a installation on a dual CPU system but I cant remember where.
I would be very pleased if any one please could help me.
Thanks in advance
Flemming
rmushtaq
Level 8
Level 8
Did you looked at the install log to see if it's clean?. What exactly is not working?. Is this Solaris 8?
kraby
I have CW2000 on dual CPU and quad CPU Sun machines, I didn't follow any special procedures, except that on the 420R there was a problem with a script that was looking for processor 0 and a dual processor 420R doesn't have a processor 0 (it has a processer 1 & 2). But this was a rather obvious problem causing the install to die without completeing - although if I recall correctly it didn't give an error message, it just died. Check psrinfo and if it doesn't list a processor 0 that might be the problem.
You problem sounds like CSCdx87041 which has a workaround and is fixed in the latest version as well.
Thanks for your help. The problem were the script as you said.
Kind regards
Flemming Iversen
