01-17-2002 11:00 AM - edited 03-01-2019 08:06 PM
Whe are using CW 2000 on a w200 server.
Each time we start The ANI server it starts ok, but after a few minutes it says that there are some problems.
This problem started after the activation of a second ethernet card. Did somebody had the same problems ?
01-17-2002 12:20 PM
Latest version of CW2000 supports Dual NIC cards. What version you're using?
01-18-2002 01:55 AM
Look at Multi-homed...
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/4steditn/rn_nt.htm#xtocid96535 if you are using 4th edition.
01-21-2002 01:34 AM
Andrea, thank you for the response and the help.
After starting the aniserver process, i'm getting the following messages in the aniserver.log file.
MESSAGE AniMain: Properties will be read from C:\PROGRA~1\CSCOpx\etc\cwsi\ANIServer.properties
Informational: ANIServer starting Cisco Process Manager communication thread
2002/01/21 10:21:12 main ani MESSAGE DBConnection: Created new Database connection [hashCode = 1936383916]
2002/01/21 10:21:14 main ani ERROR SMFFactoryLoader: java.lang.NullPointerException
2002/01/21 10:21:14 main ani ERROR AniLoadConfiguration: AniStaticConfigException: Error accessing devices--root path D:\PROGRA~1\CSCOpx\lib\classpath, packageName com.cisco.nm.ani.server.devices
Does this make sense to you ?
01-21-2002 01:25 AM
Thank you for the response.
Whe are using LMS 2.0
ANI 4.0 10-22-2001 13:23:17 none ENABLED
ANI Device Factory 4.0 10-22-2001 13:23:17 none ENABLED
Availability Manager 3.2 10-22-2001 13:39:38 none ENABLED
Client Application Manager 3.0 10-22-2001 13:23:17 none ENABLED
Change Audit Services 3.3 10-22-2001 13:39:38 none ENABLED
Configuration Archive Command Line Interface 3.3 10-22-2001 13:39:38 none ENABLED
CD One Fourth Edition 2.0 10-22-2001 13:23:17 none ENABLED
01-21-2002 10:14 AM
See the section of 'Multi-Homed Machines' at:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/4steditn/rn_nt.htm#xtocid96535 for this issue.
