Community Member
CW2K: Starting Online Help
Browser will not resolve contents/index navigator window, when online help is accessed. Online help will be working well, but left-sided navigator window stays unresolved and blanked.
What could be the cause for this behavior?
Re: CW2K: Starting Online Help
Did you changed the hostname/ip add of the CW2K server recently?. If not, then is the name/ip add resolable in DNS both from ip to name and reverse?
Community Member
No, I didn't! But, maybe, it has something to do we the following fact:
browser is called on the CW2K host via a terminal services session - depending on performance reasons! If I do the same directly on my local workstation, I do not have this resolving problems on the navigator window.
Your welcome to answer back to me.
Horst Klug
Community Member
Hi, Horst
CW2k does not currently support terminal services.
You may want to try PC anywhere or any of a dozen
other programs that do the same thing.
You will run into all kinds of problems if you have terminal server installed.
Please have a look into the bug tool kit to the
description of the problem :
Bug ID # CSCin33621
Best Regards,
Joseph Melrose
Community Member
Hi again,
I'm afraid of being in a lost position. Imagine the real complex life and structure of enterprise networks, fenced by firewall rules and so on, I suppose, I have to live with the problems.
Keep on going forward, to work out, to bring the product more in line with the needs of reality.
Best regards
Don't use terminal client. Directly use your client browser to connect to CW2K
