Community Member
CW2K Syslog Help
Hi! I am begginer in cisco work.I configure RME and Syslog Analyser and configure router to send syslog messages to RME station. In Syslog Analyser i can not see any messages. I put severity level 7 so it should log any changes.I chack status of syslog analyzer and it is working.
Thanks for help and excuse my english,
Community Member
Re: CW2K Syslog Help
Is it working or not?
Community Member
No it is not working.I am sure that a syslog service is running and when I look at the router logging I saw that the router is sending messages to my server.But when I look at the syslog.log file I can not see any logging.Clocks on server and router is OK.
THANKS FOR ANY HELP!!!!
Community Member
If you don't see anything in the syslog.log file, that means CW2k did not receive any syslog messages from your router. On your router do you have something like this configured?
logging trap notifications (severity 5 messages or higher send to syslog)
logging 172.24.25.10 (cw2k server address)
Community Member
Thanks!
Now I can see messagess in syslog.log when I changed the severity level.Problem is that I can not see it in syslog collector status in cw2k. And when i try to make raport it said that the device does not send logging traps.I have device in inventory.
I have set up also snmp on device with RW community string.
THANKS FOR ASSISTANCE AND HELP!!!!
161
