CW2kK RME 3.1 - software distribution problem
Any idea? I have tried and verfiied the and still not working.
Following is the log message from server
Running System S/W : 12.0(5.2)XU ENTERPRISE|COMMAND-CAPABLE
Upgrading System S/W : 12.0(5)WC3b ENTERPRISE|COMMAND-CAPABLE
Bootldr upgrade not selected or not applicable
Device is being locked for exclusive write access.
Connecting to device now ...
Device connected successfully
Fetching image from Image Library (for System Software Upgrade):
c3500XL-c3h2s-mz.120-5.WC3b.bin --> d:\upsdata\cw2k\CSCOpx\temp\s1rps.1
Image retrieved from library.
Loading image file to flash device : c3500XL-c3h2s-mz.120-5.WC3b.bin --> flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
Error loading image to Flash.
Error Info Code: '4175'
Message: 'Device Error: Flash copy to/from operation failed.'
Action/Reason:
'Probable Cause: The source file size and the destination file size do
notmatch. Disk space on tftp root directory may not be sufficient.
Recommended Action: Verify disk space in the TFTP directoryand
retry the operation. If the problem persists, contact your technical support
representative for assistance.'
Device has been unlocked from exclusive access.
Image Upgrade Failed
End Time : 18 Jun 2002 15:34:40 EDT Time Taken: 2 mins 31 secs
Job encountered error. Job aborted.
End of Job
Blue
Re: CW2kK RME 3.1 - software distribution problem
You need to turn on the SWIM Debug in RME, re-submit the job to capture the debugs and then may contact support for this.
following is SWIM Debug
*** Clean debug FILE
Debug level is : 9.
Debug log file is : d:\data/cw2k/CSCOpx/files/schedule/21/swim_swd.log.
Caller package is : IOSDriver.
Caller file is : d:\cw2k\CSCOpx\cgi-bin\swim\swd\IOSDriver.pm.
IOSDriver.pm 583 {8/15/2002 10:4:8}: Job '21' has been marked running in the database
JobResults.pm 542 {8/15/2002 10:4:8}: JobResults::print_job_header //class: IOS//
{8/15/2002 10:4:8}: Job Result data: Starting Job: ID - 21
{8/15/2002 10:4:8}: Job Result data: Owned by : sysssr
{8/15/2002 10:4:8}: Job Result data: Job description: 10.231.116.6
{8/15/2002 10:4:8}: Job Result data: Results e-mailed to : sryu@ups.com
{8/15/2002 10:4:8}: Job Result data: Time created : 15 Aug 2002 10:02:36 EDT
{8/15/2002 10:4:8}: Job Result data: Scheduled time : 15 Aug 2002 10:02:36 EDT
{8/15/2002 10:4:8}: Job Result data: Total number of devices in the job: 1
{8/15/2002 10:4:8}: Job Result data: Reboot devices immediately after download : yes
{8/15/2002 10:4:8}: Job Result data: Update boot commands in config file: yes
{8/15/2002 10:4:8}: Job Result data: Back up current running image: no
{8/15/2002 10:4:8}: Job Result data: Stop if error detected : no
{8/15/2002 10:4:8}: Job Result data: Use Tftp Fallback for Image Boot : no
{8/15/2002 10:4:8}: Job Result data: Job running on : {8/15/2002 10:4:8}: Job Result data: MDROACSAPPS1 {8/15/2002 10:4:8}: Job Result data: (10.231.113.100)
{8/15/2002 10:4:8}: Job Result data: Tftp Root Directory : {8/15/2002 10:4:8}: Job Result data: d:\upsdata\cw2k\CSCOpx\tftpboot
DriverUtil.pl 184 {8/15/2002 10:4:8}: DriverUtil::check_tftp_setup
TftpSvc.pm 281 {8/15/2002 10:4:8}: TftpSvc::get_tftp_root_directory
{8/15/2002 10:4:8}: SNMPsvc.pm 114 {8/15/2002 10:4:8}: SNMPsvc (new) ::STRIP_Q => 1
SNMPsvc.pm 114 {8/15/2002 10:4:8}: SNMPsvc (new) ::TRIPLET_OUTPUT => 0
SNMPsvc.pm 114 {8/15/2002 10:4:8}: SNMPsvc (new) ::SNMPSVCD_NAME => d:\upsdata\cw2k\CSCOpx/objects/swim/bin/snmpsvcd
SNMPsvc.pm 114 {8/15/2002 10:4:8}: SNMPsvc (new) ::CONNECT_ID => 6764
SNMPsvc.pm 114 {8/15/2002 10:4:8}: SNMPsvc (new) ::DEBUG => 0
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::ErrStr =>
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::PerlErr => 0
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::SvcErr => 0
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::WriteHand =>
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::SNMPVar => 0
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::SNMPErr => 0
SNMPsvc.pm 121 {8/15/2002 10:4:8}: SNMPsvc (new) ::ReadHand =>
IOSDriver.pm 623 {8/15/2002 10:4:9}: Job stop on error not selected
ConfigData.pm 129 {8/15/2002 10:4:9}: Value is 90/.
ConfigData.pm 130 {8/15/2002 10:4:9}: Expanded Value is 90.
IOSDriver.pm 632 {8/15/2002 10:4:9}: The script name is : Not specified, Timeout is : 90
DriverUtil.pl 221 {8/15/2002 10:4:9}: DriverUtil::is_job_cancelled //job_id: 21//
ConfigData.pm 129 {8/15/2002 10:4:9}: Value is $ENV{'PX_DATADIR'}/schedule/.
ConfigData.pm 130 {8/15/2002 10:4:9}: Expanded Value is d:/upsdata/cw2k/CSCOpx/files/schedule.
HistUtil.pm 770 {8/15/2002 10:4:9}: Enter format_date(1029420249)
{8/15/2002 10:4:9}: Job Result data: Processing Device : 10.231.116.6 {8/15/2002 10:4:9}: Job Result data: (#1 of 1)
{8/15/2002 10:4:9}: Job Result data: {8/15/2002 10:4:9}: Job Result data: Start Time : 15 Aug 2002 10:04:09 EDT
{8/15/2002 10:4:9}: Job Result data: {8/15/2002 10:4:9}: Job Result data: Running System S/W : 12.0(5)WC3b {8/15/2002 10:4:9}: Job Result data: ENTERPRISE|COMMAND-CAPABLE
{8/15/2002 10:4:9}: Job Result data: {8/15/2002 10:4:9}: Job Result data: Upgrading System S/W : 12.0(5)WC3b {8/15/2002 10:4:9}: Job Result data: ENTERPRISE|COMMAND-CAPABLE
{8/15/2002 10:4:9}: Job Result data: {8/15/2002 10:4:9}: Job Result data: Bootldr upgrade not selected or not applicable
IOSDriver.pm 680 {8/15/2002 10:4:9}: Contacting '10.231.116.6' (id '49') with RW Community
DriverUtil.pl 249 {8/15/2002 10:4:9}: DriverUtil::initialize_cisco_device //hostname: 10.231.116.6 device_id: 49 module: jobid: 21
DriverUtil.pl 473 {8/15/2002 10:4:9}: DriverUtil::lock_device, device: 10.231.116.6flag: 1 job id: 21
DriverUtil.pl 481 {8/15/2002 10:4:9}: jre: d:\upsdata\cw2k\CSCOpx/bin/cwjava cli-prog: com.cisco.nm.cmf.jrm.lockcli lock-param: -l owner: Software-Image-Manager-Job-21
DriverUtil.pl 497 {8/15/2002 10:4:9}: command line: -- 'd:\upsdata\cw2k\CSCOpx/bin/cwjava com.cisco.nm.cmf.jrm.lockcli -l Software-Image-Manager-Job-21 10.231.116.6@14400 2>d:/upsdata/cw2k/CSCOpx/temp\s6jc.' --
DriverUtil.pl 503 {8/15/2002 10:4:15}: return value from command: 0
DriverUtil.pl 511 {8/15/2002 10:4:15}: File contents:
DriverUtil.pl 524 {8/15/2002 10:4:15}: will set last device locked to: 10.231.116.6
{8/15/2002 10:4:15}: Job Result data: {8/15/2002 10:4:15}: Job Result data: Device is being locked for exclusive write access.
DriverUtil.pl 300 {8/15/2002 10:4:15}: Slow SNMP Timeout : 20
{8/15/2002 10:4:15}: Job Result data: {8/15/2002 10:4:15}: Job Result data: Connecting to device now ...
DeviceIOS.pm 114 {8/15/2002 10:4:15}: DeviceIOS::initialize_ios_device
DeviceIOS.pm 115 {8/15/2002 10:4:15}: //host_name = '10.231.116.6' rw_comm = '*not-printed*'//
{8/15/2002 10:4:15}: InitDevice::connect_device
{8/15/2002 10:4:15}: //host_name = '10.231.116.6' rw_comm = '*not-printed*' timeout = '10' retries = '2' //
SNMPsvc.pm 150 {8/15/2002 10:4:15}: SNMPsvc (set_timeout) ::Printing to wh106764 =timeout 1000
SNMPsvc.pm 155 {8/15/2002 10:4:15}: SNMPsvc (set_timeout) ::Reading from rh206764 '=+ timeout = 1000
SNMPsvc.pm 185 {8/15/2002 10:4:15}: SNMPsvc (set_retries) ::Printing to wh106764 =retries 2
SNMPsvc.pm 190 {8/15/2002 10:4:15}: SNMPsvc (set_retries) ::Reading from rh206764 '=+ retries = 2
{8/15/2002 10:4:15}: Inside InitDevice::connect_device resolution 1
SNMPsvc.pm 606 {8/15/2002 10:4:15}: SNMPsvc (set_host) ::Printing to wh106764 =host 10.231.116.6
SNMPsvc.pm 610 {8/15/2002 10:4:15}: SNMPsvc (set_host) ::Reading from rh206764 '=+ host = 10.231.116.6
SNMPsvc.pm 564 {8/15/2002 10:4:15}: inside SNMPsvc::set_community
SNMPsvc.pm 572 {8/15/2002 10:4:15}: SNMPsvc (set_community) ::Printing to wh106764 =community ***
SNMPsvc.pm 576 {8/15/2002 10:4:15}: SNMPsvc (set_community) ::Reading from rh206764 ********************
SNMPsvc.pm 236 {8/15/2002 10:4:15}: SNMPsvc (set_resolution) ::Printing to wh106764 =resolve 1
SNMPsvc.pm 241 {8/15/2002 10:4:15}: SNMPsvc (set_resolution) ::Reading from rh206764 '=+ resolve = 1
SNMPsvc.pm 472 {8/15/2002 10:4:15}: SNMPsvc (connect) ::Printing to wh106764: [
SNMPsvc.pm 476 {8/15/2002 10:4:21}: SNMPsvc (connect) ::Reading from rh206764: [+
DeviceIOS.pm 140 {8/15/2002 10:4:21}: Device 10.231.116.6 has been connected with Time Out: 10 value and Retries: 2
AccessInfo.pm 35 {8/15/2002 10:4:21}: AccessInfo::fill_in_telnet_access_info
AccessInfo.pm 42 {8/15/2002 10:4:21}: Local User-Password: *************
AccessInfo.pm 51 {8/15/2002 10:4:21}: TACACS User-Password: *
AccessInfo.pm 60 {8/15/2002 10:4:21}: ETACACS User-Password: *
AccessInfo.pm 69 {8/15/2002 10:4:21}: Telnet Password-Enable Password: *
AccessInfo.pm 76 {8/15/2002 10:4:21}: Enable Secret: *********
TftpSvc.pm 135 {8/15/2002 10:4:21}: TftpSvc::get_tftp_server_ip_address for 10.231.116.6
TftpSvc.pm 110 {8/15/2002 10:4:21}: NATed IP properties reading
TftpSvc.pm 144 {8/15/2002 10:4:21}: No NAT Entry Found,So skippingTftpSvc.pm 233 {8/15/2002 10:4:21}: Outgoing Interface detected as 10.231.113.100
DeviceIOS.pm 698 {8/15/2002 10:4:21}: DeviceIOS::_check_flash_mib_support
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'netConfigName'//
SNMPsvc.pm 882 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Printing to wh106764:
SNMPsvc.pm 887 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: <+
SNMPsvc.pm 897 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Printing to wh106764: ?
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ netConfigName[0]="";
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'netConfigName' result: 1//
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'chassisSysType'//
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?- <100251,2239,1> SNMP Get failed for device 10.231.116.6
SWDErrCode.pm 466 {8/15/2002 10:4:21}: Error returned in 'd:/upsdata/cw2k/CSCOpx/cgi-bin/swim/swd/SNMPErrCode.pm:121'
SWDErrCode.pm 467 {8/15/2002 10:4:21}: Error Code: '4031'
SWDErrCode.pm 468 {8/15/2002 10:4:21}: Error Message: 'Device Error: No such instance of MIB in the device.'
SWDErrCode.pm 469 {8/15/2002 10:4:21}: Error Action/Reason: 'Probable Cause: Invalid table index or MIB not supported on device. Recommended Action: Restart Resource Manager Essentials and retry the operation. If the problem persists, contact your technical support representative for assistance.'
{8/15/2002 10:4:21}: SNMP error message: Device Error: No such instance of MIB in the device.
< Low Level SNMP Code: Perl Error: -1 SNMP Error: '100251' SNMP Error2 : '2239' Var Bind: '1' SNMP Error String: 'SNMPsvc:get failed
SNMPsvc: ?- <100251,2239,1> SNMP Get failed for device 10.231.116.6
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'chassisSysType' result: 0//
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'chassisType'//
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ chassisType[0]="cat3548xl";
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'chassisType' result: 1//
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'entPhysicalVendorType[1]'//
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'entPhysicalVendorType[1]' result: 0//
DeviceIOS.pm 713 {8/15/2002 10:4:21}: device is ios class
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ sysObjectID[0]=1.3.6.1.4.1.9.1.278;
DeviceIOS.pm 726 {8/15/2002 10:4:21}: SysobjectID is: 1.3.6.1.4.1.9.1.278
DeviceIOS.pm 730 {8/15/2002 10:4:21}: device is IOS class
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ ciscoImageString[3]="CW_FAMILY$C3500XL$";
DeviceIOS.pm 741 {8/15/2002 10:4:21}: Device Class is 100
DeviceIOS.pm 742 {8/15/2002 10:4:21}: Checking whether the device is C2950
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ sysDescr[0]="Cisco Internetwork Operating System Software \r\nIOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE\r\nCopyright (c) 1986-2000 by cisco Systems, Inc.\r\nCompiled Mon 17-Jul-00 18:29 by ayounes";
DeviceIOS.pm 770 {8/15/2002 10:4:21}: sysDescr is Cisco Internetwork Operating System Software \r\nIOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE\r\nCopyright (c) 1986-2000 by cisco Systems, Inc.\r\nCompiled Mon 17-Jul-00 18:29 by ayounes
SNMPsvc.pm 901 {8/15/2002 10:4:21}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ ciscoImageString[5]="CW_VERSION$12.0(5.2)XU$";
DeviceIOS.pm 795 {8/15/2002 10:4:21}: Device Class is 100
DeviceIOS.pm 796 {8/15/2002 10:4:21}: Checking whether the device runs 12.2(5) or 12.1(11)
DeviceIOS.pm 803 {8/15/2002 10:4:21}: Image Version is CW_VERSION$12.0(5.2)XU$
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'ciscoFlashDevicesSupported'//
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'ciscoFlashDevicesSupported' result: 0//
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'flashStatus'//
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'flashStatus' result: 0//
DeviceIOS.pm 870 {8/15/2002 10:4:21}: DeviceIOS::_is_mib_var_available //mib_var_name = 'tftpHost'//
DeviceIOS.pm 888 {8/15/2002 10:4:21}: //inside is_mib_var_available mib_var_name = 'tftpHost' result: 0//
DeviceIOS.pm 203 {8/15/2002 10:4:21}: Device class for device '10.231.116.6' is: 100
DeviceIOS.pm 205 {8/15/2002 10:4:21}: Flash Mib Support for device '10.231.116.6' is 4
DeviceIOS.pm 222 {8/15/2002 10:4:21}: Initializing database in IOSJobRecord
DeviceIOS.pm 232 {8/15/2002 10:4:21}: device host name: 10.231.116.6
DeviceIOS.pm 234 {8/15/2002 10:4:21}: device id: 49
DeviceIOS.pm 242 {8/15/2002 10:4:21}: sql string is: SELECT sysObjectId FROM managed_dev, dev_type WHERE managed_dev.Device_Id = 49 AND managed_dev.Device_Type_Id = dev_type.Device_Type_Id
DeviceIOS.pm 249 {8/15/2002 10:4:21}: Amar-Before opening the Yoda Ids file
DeviceIOS.pm 252 {8/15/2002 10:4:21}: Critical Error - could not open YodaIds.dat file
ConfigIOS.pm 49 {8/15/2002 10:4:21}: ConfigIOS::initialize_fsm
DeviceIOS.pm 303 {8/15/2002 10:4:21}: config function pointers added
RebootIOS.pm 60 {8/15/2002 10:4:21}: RebootIOS::initialize_fsm_reboot
RebootIOS.pm 214 {8/15/2002 10:4:21}: RebootIOS::initialize_fsm_verify
FlashCLI.pm 93 {8/15/2002 10:4:21}: FlashCLI::initialize_fsm
FlashCLI.pm 106 {8/15/2002 10:4:21}: FlashCLI::initialize_flash_copy_fsm
FlashCLI.pm 1602 {8/15/2002 10:4:21}: FlashCLI::initialize_flash_erase_fsm
DeviceIOS.pm 313 {8/15/2002 10:4:21}: flash cli, reboot,verify function pointers added
DeviceIOS.pm 338 {8/15/2002 10:4:21}: Image Family is C3500XL
C2900XLFlashCli 116 {8/15/2002 10:4:21}: C2900XLFlashCli::initialize_fsm
C2900XLFlashCli 131 {8/15/2002 10:4:21}: C2900XLFlashCli::initialize_flash_copy_fsm
C2900XLFlashCli 1394 {8/15/2002 10:4:21}: C2900XLFlashCli::initialize_flash_misc_fsm
RSPFlashCli.pm 1699 {8/15/2002 10:4:21}: RSPFlashCli::open_telnet_connection
IosTelnet.pm 56 {8/15/2002 10:4:27}: IosTelnet::Opening a new telnet connection to 10.231.116.6 (10.231.116.6)
IosTelnet.pm 166 {8/15/2002 10:4:27}: IosTelnet::initialize_fsm
IosTelnet.pm 84 {8/15/2002 10:4:27}: IosTelnet::login
IosTelnet.pm 290 {8/15/2002 10:4:27}: Match is Username:
IosTelnet.pm 407 {8/15/2002 10:4:27}: IosTelnet::send_username ******
IosTelnet.pm 435 {8/15/2002 10:4:27}: IosTelnet::send_password
RSPFlashCli.pm 1728 {8/15/2002 10:4:27}: Device is in user mode now ...
IosTelnet.pm 137 {8/15/2002 10:4:27}: IosTelnet::enable
IosTelnet.pm 624 {8/15/2002 10:4:27}: no enable tacacs defined
IosTelnet.pm 656 {8/15/2002 10:4:27}: IosTelnet::send_enable_secret_password
DeviceIOS.pm 460 {8/15/2002 10:4:27}: Supported CLI Flash function pointers added
{8/15/2002 10:4:27}: Job Result data: {8/15/2002 10:4:27}: Job Result data: Device connected successfully
ConfigData.pm 129 {8/15/2002 10:4:27}: Value is 1/.
ConfigData.pm 130 {8/15/2002 10:4:27}: Expanded Value is 1.
ConfigData.pm 100 {8/15/2002 10:4:27}: Value is cwuser/.
ConfigData.pm 101 {8/15/2002 10:4:27}: Expanded Value is cwuser.
{8/15/2002 10:4:27}: RcpSvc::add_rhost(test, cwuser)
{8/15/2002 10:4:27}: RcpSvc::rm_rhost(test, cwuser)
SNMPsvc.pm 185 {8/15/2002 10:4:27}: SNMPsvc (set_retries) ::Printing to wh106764 =retries 3
SNMPsvc.pm 190 {8/15/2002 10:4:27}: SNMPsvc (set_retries) ::Reading from rh206764 '=+ retries = 3
{8/15/2002 10:4:27}: Retries set to : 3 (previous value: 2)
IOSDriver.pm 239 {8/15/2002 10:4:27}: default flash: flash
FlashFileName.p 88 {8/15/2002 10:4:27}: FlashFileName::get_base_file_name
FlashFileName.p 89 {8/15/2002 10:4:27}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.bin'//
ConfigIOS.pm 440 {8/15/2002 10:4:27}: ConfigIOS::get_config_register_values
SNMPsvc.pm 882 {8/15/2002 10:4:27}: SNMPsvc (_raw_get) ::Printing to wh106764:
SNMPsvc.pm 887 {8/15/2002 10:4:27}: SNMPsvc (_raw_get) ::Reading from rh206764: <+
SNMPsvc.pm 897 {8/15/2002 10:4:27}: SNMPsvc (_raw_get) ::Printing to wh106764: ?
SNMPsvc.pm 901 {8/15/2002 10:4:27}: SNMPsvc (_raw_get) ::Reading from rh206764: ?+ configRegister[0]=15;configRegNext[0]=15;
ConfigIOS.pm 450 {8/15/2002 10:4:27}: ConfigIOS::get_config_register_values:: Obtained config register values
ConfigIOS.pm 452 {8/15/2002 10:4:27}: Config Reg: 15, Config RegNext: 15
CCOImages.pm 998 {8/15/2002 10:4:27}: Inside get_image_status
CCOImages.pm 1008 {8/15/2002 10:4:27}: param = function=get_image_status&fileid=C3500XL-C3H2S-M.12.0(5)WC3b
BTCCOComm.pm 52 {8/15/2002 10:4:27}: Inside BTCCOComm->new()
BTCCOComm.pm 91 {8/15/2002 10:4:27}: Inside BTCCOComm->post_to_cgi()
BTCCOComm.pm 124 {8/15/2002 10:4:27}: POST cgi=http://www.cisco.com/cgi-bin/smarts/swim/crmiosbridge.pl;param=function=get_image_status&fileid=C3500XL-C3H2S-M.12.0(5)WC3b&crm_version=3.4
BTCCOComm.pm 132 {8/15/2002 10:4:27}: Proxy set : proxy.ups.com for Proxy user
UpgradeUtil.pm 437 {8/15/2002 10:4:46}: Entering UpgradeUtil::copy_systemsw_file(sw_context)
UpgradeUtil.pm 445 {8/15/2002 10:4:46}: Initializing database in upgradeutil
UpgradeUtil.pm 454 {8/15/2002 10:4:46}: device host name: 10.231.116.6
UpgradeUtil.pm 456 {8/15/2002 10:4:46}: device id: 49
UpgradeUtil.pm 463 {8/15/2002 10:4:46}: sql string is: SELECT sysObjectId FROM managed_dev, dev_type WHERE managed_dev.Device_Id = 49 AND managed_dev.Device_Type_Id = dev_type.Device_Type_Id
UpgradeUtil.pm 473 {8/15/2002 10:4:46}: Murali-Parsing going on
UpgradeUtil.pm 478 {8/15/2002 10:4:46}: Inside file read - 1.3.6.1.4.1.9.1.380
UpgradeUtil.pm 478 {8/15/2002 10:4:46}: Inside file read - 1.3.6.1.4.1.9.1.379
UpgradeUtil.pm 93 {8/15/2002 10:4:46}: Entering UpgradeUtil::get_image_file_from_slim (IOS, 1, c3500XL-c3h2s-mz.120-5.WC3b.tar, d:/upsdata/cw2k/CSCOpx/temp\s6jc.1, System Software Upgrade, )
{8/15/2002 10:4:46}: Job Result data: {8/15/2002 10:4:46}: Job Result data:
{8/15/2002 10:4:46}: Job Result data: {8/15/2002 10:4:46}: Job Result data: Fetching image from Image Library {8/15/2002 10:4:46}: Job Result data: (for System Software Upgrade):
{8/15/2002 10:4:46}: Job Result data: c3500XL-c3h2s-mz.120-5.WC3b.tar --> d:\upsdata\cw2k\CSCOpx\temp\s6jc.1
SlimFileMngt.pm 548 {8/15/2002 10:4:46}: Entering SlimFileMngt::get_file(0, 1, c3500XL-c3h2s-mz.120-5.WC3b.tar, d:/upsdata/cw2k/CSCOpx/temp\s6jc.1, )
ConfigData.pm 129 {8/15/2002 10:4:46}: Value is $ENV{'PX_DATADIR'}/sw_images/.
ConfigData.pm 130 {8/15/2002 10:4:46}: Expanded Value is d:/upsdata/cw2k/CSCOpx/files/sw_images.
SlimFileMngt.pm 598 {8/15/2002 10:4:46}: {SlimFileMngt::get_file} : Copying the image file 'd:/upsdata/cw2k/CSCOpx/files/sw_images/ios/system/c3500XL-c3h2s-mz.120-5.WC3b.tar.gz' to 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1.gz'
SWIMCompress.pm 157 {8/15/2002 10:4:46}: Entering SWIMCompress::uncompress_file(d:/upsdata/cw2k/CSCOpx/temp\s6jc.1.gz)
SWIMCompress.pm 184 {8/15/2002 10:4:46}: {SWIMCompress::uncompress_file} : The file 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1.gz' is compressed with extension '.gz'
SWIMCompress.pm 205 {8/15/2002 10:4:46}: {SWIMCompress::uncompress_file} : Uncompressing with the following command: 'gzip -q -f -d d:/upsdata/cw2k/CSCOpx/temp\s6jc.1.gz'
SWIMCompress.pm 221 {8/15/2002 10:4:46}: {SWIMCompress::uncompress_file} : Completed uncompression of 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1.gz' to 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1'.
SlimCommon.pm 400 {8/15/2002 10:4:46}: get_image_table (Class : 0 Image Type : 1)
SlimFileMngt.pm 636 {8/15/2002 10:4:46}: {SlimFileMngt::get_file} : md5 checksum from databse for 'c3500XL-c3h2s-mz.120-5.WC3b.tar' = 2c86b6da4d88d5997770cd82ede9d35a
SlimFileMngt.pm 648 {8/15/2002 10:4:46}: {SlimFileMngt::get_file} : md5 checksum of 'c3500XL-c3h2s-mz.120-5.WC3b.tar' = 2c86b6da4d88d5997770cd82ede9d35a
CommonImg.pm 634 {8/15/2002 10:4:46}: Entering CommonImg::is_compressed_file(d:/upsdata/cw2k/CSCOpx/temp\s6jc.1)
CommonImg.pm 652 {8/15/2002 10:4:46}: {CommonImg::is_compressed_file} : 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1' is NOT a supported compressed file
{8/15/2002 10:4:46}: Job Result data: {8/15/2002 10:4:46}: Job Result data: Image retrieved from library.
{8/15/2002 10:4:46}: Job Result data: {8/15/2002 10:4:46}: Job Result data: Loading image file to flash device : {8/15/2002 10:4:46}: Job Result data: c3500XL-c3h2s-mz.120-5.WC3b.tar --> flash:c3500XL-c3h2s-mz.120-5.WC3b.tar
{8/15/2002 10:4:46}: Job Result data: {8/15/2002 10:4:46}: Job Result data: Running image will be overwritten by the new image ...
UpgradeUtil.pm 672 {8/15/2002 10:4:46}: Inside isMSFC2_image_with_7A
UpgradeUtil.pm 676 {8/15/2002 10:4:46}: Running image family - 'C3500XL'
UpgradeUtil.pm 677 {8/15/2002 10:4:46}: Running image version -'12.0(5)WC3b'
C2900XLFlashCli 1241 {8/15/2002 10:4:46}: setting telnet log to: d:/upsdata/cw2k/CSCOpx/files/schedule/21
C2900XLFlashCli 1243 {8/15/2002 10:4:46}: C2900XLFlashCli::load_flash_file
C2900XLFlashCli 1244 {8/15/2002 10:4:46}: //src_flash_file_name = 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1', dst_flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar', erase_flash_flag = '1'//
FlashFileName.p 88 {8/15/2002 10:4:46}: FlashFileName::get_base_file_name
FlashFileName.p 89 {8/15/2002 10:4:46}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar'//
C2900XLFlashCli 1284 {8/15/2002 10:4:47}: Found matching version 12.0(5)WC3b for : c3500XL-c3h2s-mz.120-5.WC3b.bin
C2900XLFlashCli 1296 {8/15/2002 10:4:47}: Found filename for IOS image : c3500XL-c3h2s-mz.120-5.WC3b.bin, Size is 1751867
FlashFileName.p 61 {8/15/2002 10:4:47}: FlashFileName::get_flash_partition_name
FlashFileName.p 62 {8/15/2002 10:4:47}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar'//
C2900XLFlashCli 1649 {8/15/2002 10:4:47}: C2900XLFlashCli::get_flash_device_info flash_part_name = 'flash'
C2900XLFlashCli 1698 {8/15/2002 10:4:47}: Avail: 934400 Used: 2678272 Total:
C2900XLFlashCli 1715 {8/15/2002 10:4:47}: CRITICAL ERROR... FILE INFO --- C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMECHECKSUMundefSIZEPERMISSIONSSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: Permissions: Length:
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEc3500XL-c3h2s-mz-120.5.2-XU.binCHECKSUMundefSIZE1645807PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: c3500XL-c3h2s-mz-120.5.2-XU.bin Permissions: -rwx Length: 1645807
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEhtmlCHECKSUMundefSIZE6720PERMISSIONSdrwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: html Permissions: drwx Length: 6720
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEinfoCHECKSUMundefSIZE108PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: info Permissions: -rwx Length: 108
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEvlan.datCHECKSUMundefSIZE2664PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: vlan.dat Permissions: -rwx Length: 2664
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEinfo.verCHECKSUMundefSIZE108PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: info.ver Permissions: -rwx Length: 108
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEenv_varsCHECKSUMundefSIZE318PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: env_vars Permissions: -rwx Length: 318
C2900XLFlashCli 1734 {8/15/2002 10:4:47}: FILE INFO --- NAMEconfig.textCHECKSUMundefSIZE2600PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:4:47}: Filename: config.text Permissions: -rwx Length: 2600
C2900XLFlashCli 1329 {8/15/2002 10:4:47}: Pre load_flash_file checks on file size passed
TftpSvc.pm 681 {8/15/2002 10:4:47}: TftpSvc::get_file_checksum Algo Type: simpleCRC File Name: d:/upsdata/cw2k/CSCOpx/temp\s6jc.1
TftpSvc.pm 713 {8/15/2002 10:4:47}: executing 'd:\upsdata\cw2k\CSCOpx/objects/swim/bin/cksum.exe crc "d:/upsdata/cw2k/CSCOpx/temp\s6jc.1"' to calculate checksum
TftpSvc.pm 722 {8/15/2002 10:4:47}: checksum cmd returned for d:/upsdata/cw2k/CSCOpx/temp\s6jc.1: '0xC066062B
C2900XLFlashCli 1366 {8/15/2002 10:4:47}: flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
C2900XLFlashCli 1379 {8/15/2002 10:4:47}: Maximum Retries: 87 estimate time: 5273.6
C2900XLFlashCli 1751 {8/15/2002 10:4:47}: Attempting to delete file: flash:html/Snmp/*
C2900XLFlashCli 1906 {8/15/2002 10:4:47}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:html/Snmp/*'
C2900XLFlashCli 1415 {8/15/2002 10:4:47}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:4:47}: init_flash_misc_operation -- delete flash:html/Snmp/*C2900XLFlashCli 1963 {8/15/2002 10:4:47}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:4:47}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:4:47}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:4:47}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:4:51}: Things are defined here Pre: 'delete flash:html/Snmp/*
' Match:'Delete filename' more data: ' [html/Snmp/*]? '
C2900XLFlashCli 1963 {8/15/2002 10:4:51}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:4:51}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:4:51}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:4:51}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:4:51}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:4:55}: Things are defined here Pre: '
%Error opening flash:html/Snmp/ (No such file or directory)
' Match:'Switch#' more data: ''
C2900XLFlashCli 1504 {8/15/2002 10:4:55}: Device erased the file!
C2900XLFlashCli 1772 {8/15/2002 10:4:55}: Delete operation on flash:html/Snmp/* successful ..
C2900XLFlashCli 1906 {8/15/2002 10:4:55}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:html/Snmp'
C2900XLFlashCli 1415 {8/15/2002 10:4:55}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:4:55}: init_flash_misc_operation -- rmdir flash:html/SnmpC2900XLFlashCli 1963 {8/15/2002 10:4:55}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:4:55}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:4:55}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:4:55}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:4:59}: Things are defined here Pre: 'rmdir flash:html/Snmp
' Match:'Rmdir filename' more data: ' [html/Snmp]? '
C2900XLFlashCli 1963 {8/15/2002 10:4:59}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:4:59}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:4:59}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:4:59}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:4:59}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:3}: Things are defined here Pre: '
' Match:'Delete flash:html/Snmp? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:3}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:3}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:3}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:3}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:3}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:7}: Things are defined here Pre: '
%Error Removing dir flash:html/Snmp (No such file or directory)
C2900XLFlashCli 1504 {8/15/2002 10:5:7}: Device erased the file!
C2900XLFlashCli 1795 {8/15/2002 10:5:7}: Delete operation on flash:html/Snmp successful ..
C2900XLFlashCli 1906 {8/15/2002 10:5:7}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:html/*'
C2900XLFlashCli 1415 {8/15/2002 10:5:7}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:5:7}: init_flash_misc_operation -- delete flash:html/*C2900XLFlashCli 1963 {8/15/2002 10:5:7}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:5:7}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:9}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:9}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:13}: Things are defined here Pre: 'delete flash:html/*
' Match:'Delete filename' more data: ' [html/*]? '
C2900XLFlashCli 1963 {8/15/2002 10:5:13}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:5:13}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:5:13}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:13}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:13}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:17}: Things are defined here Pre: '
' Match:'Delete flash:html/ClusterBuilder.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:17}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:17}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:17}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:17}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:17}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:21}: Things are defined here Pre: '
' Match:'Delete flash:html/ClusterManager.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:21}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:21}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:21}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:21}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:21}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:25}: Things are defined here Pre: '
' Match:'Delete flash:html/Graph.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:25}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:25}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:25}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:25}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:25}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:29}: Things are defined here Pre: '
' Match:'Delete flash:html/back.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:29}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:29}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:29}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:29}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:29}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:33}: Things are defined here Pre: '
' Match:'Delete flash:html/basiccfg.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:33}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:33}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:33}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:33}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:33}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:37}: Things are defined here Pre: '
' Match:'Delete flash:html/switchmgr.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:37}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:37}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:37}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:37}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:37}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:41}: Things are defined here Pre: '
' Match:'Delete flash:html/blank.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:41}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:41}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:41}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:41}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:41}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:45}: Things are defined here Pre: '
' Match:'Delete flash:html/cluster.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:45}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:45}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:45}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:45}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:45}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:49}: Things are defined here Pre: '
' Match:'Delete flash:html/menu.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:49}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:49}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:49}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:49}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:49}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:53}: Things are defined here Pre: '
' Match:'Delete flash:html/port.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:53}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:53}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:53}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:53}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:53}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:5:57}: Things are defined here Pre: '
' Match:'Delete flash:html/cv.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:5:57}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:5:57}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:5:57}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:5:57}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:5:57}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:1}: Things are defined here Pre: '
' Match:'Delete flash:html/popup.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:1}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:1}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:1}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:1}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:1}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:5}: Things are defined here Pre: '
' Match:'Delete flash:html/Detective.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:5}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:5}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:5}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:5}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:5}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:9}: Things are defined here Pre: '
' Match:'Delete flash:html/DrawGraph.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:9}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:9}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:9}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:10}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:10}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:14}: Things are defined here Pre: '
' Match:'Delete flash:html/GraphFrame.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:14}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:14}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:14}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:14}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:14}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:18}: Things are defined here Pre: '
' Match:'Delete flash:html/GraphFrameIE.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:18}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:18}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:18}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:18}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:18}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:22}: Things are defined here Pre: '
' Match:'Delete flash:html/ieGraph.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:22}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:22}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:22}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:22}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:22}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:26}: Things are defined here Pre: '
' Match:'Delete flash:html/malibu.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:26}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:26}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:26}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:26}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:26}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:30}: Things are defined here Pre: '
' Match:'Delete flash:html/topmenu.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:30}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:30}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:30}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:30}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:30}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:34}: Things are defined here Pre: '
' Match:'Delete flash:html/setprefs.html.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:34}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:34}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:34}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:34}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:34}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:38}: Things are defined here Pre: '
' Match:'Delete flash:html/CM.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:38}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:38}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:38}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:39}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:39}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:43}: Things are defined here Pre: '
' Match:'Delete flash:html/CBCV.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:43}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:43}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:43}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:43}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:43}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:47}: Things are defined here Pre: '
' Match:'Delete flash:html/common.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:47}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:47}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:47}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:48}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:48}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:52}: Things are defined here Pre: '
' Match:'Delete flash:html/shared.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:52}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:52}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:52}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:52}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:52}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:6:56}: Things are defined here Pre: '
' Match:'Delete flash:html/devicerep.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:6:56}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:6:56}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:6:56}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:6:56}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:6:56}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:0}: Things are defined here Pre: '
' Match:'Delete flash:html/graph.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:0}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:0}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:0}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:0}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:0}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:4}: Things are defined here Pre: '
' Match:'Delete flash:html/snmp.jar? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:4}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:4}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:4}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:4}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:4}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:8}: Things are defined here Pre: '
' Match:'Delete flash:html/cvsm.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:8}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:8}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:8}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:8}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:8}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:12}: Things are defined here Pre: '
' Match:'Delete flash:html/close.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:12}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:12}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:12}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:12}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:12}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:16}: Things are defined here Pre: '
' Match:'Delete flash:html/detective.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:16}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:16}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:16}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:16}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:16}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:20}: Things are defined here Pre: '
' Match:'Delete flash:html/graph.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:20}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:20}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:20}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:20}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:20}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:24}: Things are defined here Pre: '
' Match:'Delete flash:html/help.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:24}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:24}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:24}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:24}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:24}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:28}: Things are defined here Pre: '
' Match:'Delete flash:html/link.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:28}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:28}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:28}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:28}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:28}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:32}: Things are defined here Pre: '
' Match:'Delete flash:html/webconsole.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:32}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:32}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:32}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:32}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:32}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:36}: Things are defined here Pre: '
' Match:'Delete flash:html/sibu.gif? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:36}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:36}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:36}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:36}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:36}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:40}: Things are defined here Pre: '
' Match:'Delete flash:html/devrpt2.htm? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:40}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:40}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:40}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:40}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:40}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:44}: Things are defined here Pre: '
' Match:'Delete flash:html/linkrpt2.htm? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:44}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:44}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:44}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:44}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:44}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:48}: Things are defined here Pre: '
' Match:'Delete flash:html/homepage.htm? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:48}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:48}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:48}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:48}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:48}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:52}: Things are defined here Pre: '
' Match:'Delete flash:html/addrmgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:52}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:52}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:52}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:52}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:52}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:7:56}: Things are defined here Pre: '
' Match:'Delete flash:html/adminfo.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:7:56}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:7:56}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:7:56}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:7:56}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:7:56}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:0}: Things are defined here Pre: '
' Match:'Delete flash:html/arptabl.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:0}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:0}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:0}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:0}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:0}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:4}: Things are defined here Pre: '
' Match:'Delete flash:html/bandwdth.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:4}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:4}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:4}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:4}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:4}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:8}: Things are defined here Pre: '
' Match:'Delete flash:html/baudrate.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:8}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:8}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:8}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:9}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:9}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:13}: Things are defined here Pre: '
' Match:'Delete flash:html/cgmpcfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:13}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:13}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:13}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:13}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:13}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:17}: Things are defined here Pre: '
' Match:'Delete flash:html/clstbldr.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:17}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:17}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:17}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:17}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:17}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:21}: Things are defined here Pre: '
' Match:'Delete flash:html/clstrmgr.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:21}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:21}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:21}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:21}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:21}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:25}: Things are defined here Pre: '
' Match:'Delete flash:html/clstview.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:25}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:25}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:25}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:25}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:25}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:29}: Things are defined here Pre: '
' Match:'Delete flash:html/cmdcfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:29}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:29}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:29}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:29}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:29}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:33}: Things are defined here Pre: '
' Match:'Delete flash:html/d_baudrat.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:33}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:33}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:33}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:33}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:33}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:37}: Things are defined here Pre: '
' Match:'Delete flash:html/d_bndwth.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:37}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:37}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:37}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:37}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:37}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:41}: Things are defined here Pre: '
' Match:'Delete flash:html/d_invent.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:41}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:41}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:41}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:41}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:41}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:45}: Things are defined here Pre: '
' Match:'Delete flash:html/d_ipmgt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:45}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:45}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:45}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:45}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:45}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:49}: Things are defined here Pre: '
' Match:'Delete flash:html/d_linkgr.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:49}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:49}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:49}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:49}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:49}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:53}: Things are defined here Pre: '
' Match:'Delete flash:html/d_mgvlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:53}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:53}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:53}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:53}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:53}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:8:57}: Things are defined here Pre: '
' Match:'Delete flash:html/d_reload.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:8:57}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:8:57}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:8:57}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:8:57}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:8:57}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:1}: Things are defined here Pre: '
' Match:'Delete flash:html/d_usrset.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:1}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:1}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:1}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:1}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:1}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:5}: Things are defined here Pre: '
' Match:'Delete flash:html/devposn.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:5}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:5}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:5}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:5}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:5}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:9}: Things are defined here Pre: '
' Match:'Delete flash:html/ethvlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:9}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:9}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:9}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:9}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:9}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:13}: Things are defined here Pre: '
' Match:'Delete flash:html/fddivlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:13}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:13}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:13}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:13}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:13}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:17}: Things are defined here Pre: '
' Match:'Delete flash:html/floodctl.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:17}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:17}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:17}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:17}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:17}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:21}: Things are defined here Pre: '
' Match:'Delete flash:html/fnetvlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:21}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:21}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:21}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:21}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:21}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:25}: Things are defined here Pre: '
' Match:'Delete flash:html/ipmgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:25}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:25}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:25}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:25}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:25}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:29}: Things are defined here Pre: '
' Match:'Delete flash:html/linkgrph.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:29}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:29}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:29}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:29}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:29}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:33}: Things are defined here Pre: '
' Match:'Delete flash:html/linkrpt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:33}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:33}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:33}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:33}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:33}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:37}: Things are defined here Pre: '
' Match:'Delete flash:html/mgmtvlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:37}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:37}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:37}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:37}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:37}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:41}: Things are defined here Pre: '
' Match:'Delete flash:html/pop_port.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:41}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:41}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:41}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:41}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:41}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:45}: Things are defined here Pre: '
' Match:'Delete flash:html/portcfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:45}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:45}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:45}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:45}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:45}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:49}: Things are defined here Pre: '
' Match:'Delete flash:html/portgrp.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:49}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:49}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:49}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:49}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:49}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:53}: Things are defined here Pre: '
' Match:'Delete flash:html/portsec.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:53}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:53}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:53}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:53}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:53}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:9:57}: Things are defined here Pre: '
' Match:'Delete flash:html/reload.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:9:57}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:9:57}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:9:57}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:9:57}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:9:57}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:1}: Things are defined here Pre: '
' Match:'Delete flash:html/snmpmgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:1}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:2}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:2}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:2}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:2}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:6}: Things are defined here Pre: '
' Match:'Delete flash:html/spancfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:6}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:6}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:6}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:6}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:6}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:10}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:10}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:10}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:10}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:10}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:10}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:14}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_flod.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:14}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:14}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:14}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:14}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:14}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:18}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_invn.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:18}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:18}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:18}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:18}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:18}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:22}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_ipmg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:22}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:22}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:22}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:22}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:22}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:26}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_link.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:26}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:26}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:26}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:26}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:26}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:30}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_mvln.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:30}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:30}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:30}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:30}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:30}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:34}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_pgrp.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:34}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:34}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:34}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:34}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:34}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:38}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_port.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:38}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:38}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:38}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:38}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:38}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:42}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_psec.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:42}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:42}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:42}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:42}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:42}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:46}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_span.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:46}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:46}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:46}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:46}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:46}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:50}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_time.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:50}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:50}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:50}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:50}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:50}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:54}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_uset.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:54}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:54}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:54}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:54}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:54}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:10:58}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_vlan.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:10:58}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:10:58}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:10:58}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:10:58}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:10:58}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:2}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp_vtp.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:2}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:2}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:2}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:2}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:2}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:6}: Things are defined here Pre: '
' Match:'Delete flash:html/standby.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:6}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:6}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:6}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:6}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:6}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:10}: Things are defined here Pre: '
' Match:'Delete flash:html/stpcfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:10}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:10}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:10}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:10}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:10}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:14}: Things are defined here Pre: '
' Match:'Delete flash:html/suggcand.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:14}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:14}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:14}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:14}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:14}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:18}: Things are defined here Pre: '
' Match:'Delete flash:html/timemgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:18}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:18}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:18}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:18}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:18}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:22}: Things are defined here Pre: '
' Match:'Delete flash:html/tringvln.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:22}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:22}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:22}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:22}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:22}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:26}: Things are defined here Pre: '
' Match:'Delete flash:html/trnetvln.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:26}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:26}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:26}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:26}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:26}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:30}: Things are defined here Pre: '
' Match:'Delete flash:html/upgrade.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:30}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:30}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:30}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:30}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:30}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:34}: Things are defined here Pre: '
' Match:'Delete flash:html/usersets.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:34}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:34}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:34}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:34}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:34}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:38}: Things are defined here Pre: '
' Match:'Delete flash:html/vlanmgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:38}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:38}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:38}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:38}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:38}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:42}: Things are defined here Pre: '
' Match:'Delete flash:html/vlanrule.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:42}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:42}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:42}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:42}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:42}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:46}: Things are defined here Pre: '
' Match:'Delete flash:html/vmpscfg.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:46}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:46}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:46}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:46}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:46}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:50}: Things are defined here Pre: '
' Match:'Delete flash:html/vsm.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:50}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:50}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:50}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:51}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:51}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:55}: Things are defined here Pre: '
' Match:'Delete flash:html/vtpmgmt.htm.gz? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:55}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:55}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:55}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:55}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:55}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:11:59}: Things are defined here Pre: '
' Match:'Delete flash:html/clstbldr.toc? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:11:59}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:11:59}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:11:59}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:11:59}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:11:59}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:3}: Things are defined here Pre: '
' Match:'Delete flash:html/clstmgr.toc? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:3}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:3}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:3}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:3}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:3}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:7}: Things are defined here Pre: '
' Match:'Delete flash:html/cvsm.toc? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:7}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:7}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:7}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:7}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:7}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:11}: Things are defined here Pre: '
' Match:'Delete flash:html/ssp.toc? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:11}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:11}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:11}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:11}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:11}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:15}: Things are defined here Pre: '
' Match:'Delete flash:html/prefs.text? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:15}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:15}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:15}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:15}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:15}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:19}: Things are defined here Pre: '
' Match:'Delete flash:html/version.txt? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:19}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:19}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:19}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:19}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:19}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:23}: Things are defined here Pre: '
' Match:'Switch#' more data: ''
C2900XLFlashCli 1504 {8/15/2002 10:12:23}: Device erased the file!
C2900XLFlashCli 1817 {8/15/2002 10:12:23}: Delete operation on flash:html/* successful ..
C2900XLFlashCli 1906 {8/15/2002 10:12:23}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:html'
C2900XLFlashCli 1415 {8/15/2002 10:12:23}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:12:23}: init_flash_misc_operation -- rmdir flash:htmlC2900XLFlashCli 1963 {8/15/2002 10:12:23}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:12:23}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:23}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:23}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:27}: Things are defined here Pre: 'rmdir flash:html
' Match:'Rmdir filename' more data: ' [html]? '
C2900XLFlashCli 1963 {8/15/2002 10:12:27}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:12:27}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:12:27}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:27}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:27}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:31}: Things are defined here Pre: '
' Match:'Delete flash:html? [confirm]' more data: ''
C2900XLFlashCli 1963 {8/15/2002 10:12:31}: C2900XLFlashCli::print_command
C2900XLFlashCli 1500 {8/15/2002 10:12:31}: Device asked erase the given filename? [confirm]C2900XLFlashCli 1443 {8/15/2002 10:12:31}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:31}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:31}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:35}: Things are defined here Pre: '
' Match:'Removed dir' more data: ' flash:html
Switch#'
C2900XLFlashCli 1504 {8/15/2002 10:12:35}: Device erased the file!
C2900XLFlashCli 1840 {8/15/2002 10:12:35}: Delete operation on flash:html successful ..
C2900XLFlashCli 1844 {8/15/2002 10:12:35}: Attempting to delete file: flash:c2900XL-diag-mz*
C2900XLFlashCli 1906 {8/15/2002 10:12:35}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:c2900XL-diag-mz*'
C2900XLFlashCli 1415 {8/15/2002 10:12:35}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:12:35}: init_flash_misc_operation -- delete flash:c2900XL-diag-mz*C2900XLFlashCli 1963 {8/15/2002 10:12:35}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:12:35}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:35}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:35}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:39}: Things are defined here Pre: 'delete flash:c2900XL-diag-mz*
' Match:'Delete filename' more data: ' [c2900XL-diag-mz*]? '
C2900XLFlashCli 1963 {8/15/2002 10:12:39}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:12:39}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:12:39}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:39}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:39}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:43}: Things are defined here Pre: '
No such file
C2900XLFlashCli 1504 {8/15/2002 10:12:43}: Device erased the file!
C2900XLFlashCli 1866 {8/15/2002 10:12:43}: Delete operation on flash:c2900XL-diag-mz* successful ..
C2900XLFlashCli 1870 {8/15/2002 10:12:43}: Attempting to delete file: flash:c3500XL-diag-mz*
C2900XLFlashCli 1906 {8/15/2002 10:12:43}: C2900XLFlashCli::delete_flash_file flash_file_name = 'flash:c3500XL-diag-mz*'
C2900XLFlashCli 1415 {8/15/2002 10:12:43}: C2900XLFlashCli::init_flash_misc_operation
C2900XLFlashCli 1425 {8/15/2002 10:12:43}: init_flash_misc_operation -- delete flash:c3500XL-diag-mz*C2900XLFlashCli 1963 {8/15/2002 10:12:43}: C2900XLFlashCli::print_command
C2900XLFlashCli 1443 {8/15/2002 10:12:43}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:43}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:43}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:47}: Things are defined here Pre: 'delete flash:c3500XL-diag-mz*
' Match:'Delete filename' more data: ' [c3500XL-diag-mz*]? '
C2900XLFlashCli 1963 {8/15/2002 10:12:47}: C2900XLFlashCli::print_command
C2900XLFlashCli 1489 {8/15/2002 10:12:47}: Device asked erase the given filename?C2900XLFlashCli 1443 {8/15/2002 10:12:47}: C2900XLFlashCli::interact_flash_misc_operation
C2900XLFlashCli 1468 {8/15/2002 10:12:47}: C2900XLFlashCli::interact_flash_misc_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:12:47}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 1474 {8/15/2002 10:12:51}: Things are defined here Pre: '
No such file
C2900XLFlashCli 1504 {8/15/2002 10:12:51}: Device erased the file!
C2900XLFlashCli 1892 {8/15/2002 10:12:51}: Delete operation on flash:c3500XL-diag-mz* successful ..
C2900XLFlashCli 1896 {8/15/2002 10:12:51}: 6 out of 6 Delete operations are successful
C2900XLFlashCli 191 {8/15/2002 10:12:51}: C2900XLFlashCli::init_flash_operation
ConfigData.pm 129 {8/15/2002 10:12:51}: Value is 1/.
ConfigData.pm 130 {8/15/2002 10:12:51}: Expanded Value is 1.
{8/15/2002 10:12:51}: RcpSvc::add_rhost(10.231.116.6, cwuser)
FlashCLI.pm 2006 {8/15/2002 10:12:51}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:12:51}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:12:51}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:12:51}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:12:51}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:12:55}: Device received config terminal command prematch: config terminal
match: Enter configuration commands, one per line. End with CNTL/Z more_data: .
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:12:55}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:12:55}: Command to send : ip rcmd remote-user cwuser
FlashCLI.pm 2419 {8/15/2002 10:12:55}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:12:55}: Command to send : exit
FlashFileName.p 88 {8/15/2002 10:12:55}: FlashFileName::get_base_file_name
FlashFileName.p 89 {8/15/2002 10:12:55}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar'//
TftpSvc.pm 429 {8/15/2002 10:12:55}: TftpSvc::create_empty_tftp_file
TftpSvc.pm 430 {8/15/2002 10:12:55}: //file_name = ''//
TftpSvc.pm 281 {8/15/2002 10:12:55}: TftpSvc::get_tftp_root_directory
TftpSvc.pm 388 {8/15/2002 10:12:55}: TftpSvc::get_temp_tftp_file_namedst_dir = 'd:\upsdata\cw2k\CSCOpx\tftpboot'
TftpSvc.pm 414 {8/15/2002 10:12:55}: TftpSvc::get_temp_tftp_file_name returning filename: 'px_sw_5714_6764'
TftpSvc.pm 465 {8/15/2002 10:12:55}: Creating file with name: d:\upsdata\cw2k\CSCOpx\tftpboot/px_sw_5714_6764..
TftpSvc.pm 589 {8/15/2002 10:12:55}: TftpSvc::copy_file_to_tftp TftpSvc.pm 590 {8/15/2002 10:12:55}: //src_file_name = 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1', dst_file_name = 'px_sw_5714_6764'//
TftpSvc.pm 611 {8/15/2002 10:12:55}: TftpSvc::copy_file TftpSvc.pm 612 {8/15/2002 10:12:55}: //src_file_name = 'd:/upsdata/cw2k/CSCOpx/temp\s6jc.1',dst_file_name = 'd:\upsdata\cw2k\CSCOpx\tftpboot/px_sw_5714_6764' create_mode = '511'//
TftpSvc.pm 615 {8/15/2002 10:12:55}: Copying file d:/upsdata/cw2k/CSCOpx/temp\s6jc.1 => d:\upsdata\cw2k\CSCOpx\tftpboot/px_sw_5714_6764
TftpSvc.pm 621 {8/15/2002 10:12:56}: Copied 3164160C2900XLFlashCli 263 {8/15/2002 10:12:56}: Going to rename_flash_operation
FlashCLI.pm 2006 {8/15/2002 10:12:56}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:12:56}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:12:56}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:12:56}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:12:56}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:13:0}: Device received config terminal command prematch: config terminal
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:13:0}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:13:0}: Command to send : no ip http server
FlashCLI.pm 2419 {8/15/2002 10:13:0}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:13:0}: Command to send : exit
C2900XLFlashCli 465 {8/15/2002 10:13:0}: Running File Name : flash:c3500XL-c3h2s-mz.120-5.WC3b.bin, Target Name : flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
C2900XLFlashCli 548 {8/15/2002 10:13:0}: Command to run is rename flash:c3500XL-c3h2s-mz-120.5.2-XU.bin flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
C2900XLFlashCli 1963 {8/15/2002 10:13:0}: C2900XLFlashCli::print_command
C2900XLFlashCli 565 {8/15/2002 10:13:0}: C2900XLFlashCli::interact_flash_operation
C2900XLFlashCli 584 {8/15/2002 10:13:0}: C2900XLFlashCli::interact_flash_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:13:0}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 590 {8/15/2002 10:13:4}: Things are defined here Pre: 'rename flash:c3500XL-c3h2s-mz-120.5.2-XU.bin flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
' Match:'Destination filename [c3500XL-c3h2s-mz.120-5.WC3b.bin]?' more data: ' '
C2900XLFlashCli 1963 {8/15/2002 10:13:4}: C2900XLFlashCli::print_command
C2900XLFlashCli 610 {8/15/2002 10:13:4}: Device asked for Destination filename filename: C2900XLFlashCli 565 {8/15/2002 10:13:4}: C2900XLFlashCli::interact_flash_operation
C2900XLFlashCli 584 {8/15/2002 10:13:4}: C2900XLFlashCli::interact_flash_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:13:4}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 590 {8/15/2002 10:13:8}: Things are defined here Pre: 'flash:c3500XL-c3h2s-mz.120-5.WC3b.bin
C2900XLFlashCli 630 {8/15/2002 10:13:8}: Rename operation finished.FlashFileName.p 61 {8/15/2002 10:13:8}: FlashFileName::get_flash_partition_name
FlashFileName.p 62 {8/15/2002 10:13:8}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar'//
TftpSvc.pm 499 {8/15/2002 10:13:8}: TftpSvc::get_fullpath TftpSvc.pm 500 {8/15/2002 10:13:8}: //file_name = 'px_sw_5714_6764'//
TftpSvc.pm 281 {8/15/2002 10:13:8}: TftpSvc::get_tftp_root_directory
C2900XLFlashCli 1963 {8/15/2002 10:13:8}: C2900XLFlashCli::print_command
C2900XLFlashCli 289 {8/15/2002 10:13:8}: C2900XLFlashCli::interact_flash_operation
C2900XLFlashCli 309 {8/15/2002 10:13:17}: C2900XLFlashCli::interact_flash_operation wait for returned
C2900XLFlashCli 1934 {8/15/2002 10:13:17}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 315 {8/15/2002 10:13:21}: Things are defined here Pre: 'tar /xtract rcp://10.231.113.100/d:\upsdata\cw2k\CSCOpx\tftpboot/px_sw_5714_6764 flash:
Connected to 10.231.113.100
' Match:'Loading 3164160 byte file px_sw_5714_6764: ' more data: '
extracting info (109 bytes)!!'
C2900XLFlashCli 336 {8/15/2002 10:13:21}: Copy procedure started ...
C2900XLFlashCli 691 {8/15/2002 10:13:21}: C2900XLFlashCli::check_flash_operation_status
C2900XLFlashCli 710 {8/15/2002 10:13:21}: Processing left over data from interact_flash_operation inside check_flash_operation_status function
C2900XLFlashCli 723 {8/15/2002 10:13:21}: wait returned/left over data inside check_flash_operation_status pre-match: '' match: '
C2900XLFlashCli 1934 {8/15/2002 10:13:21}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 732 {8/15/2002 10:13:25}: wait ret inside (2) check_flash_operation_status pre-match: '' match: '
extracting info (109 bytes)!!' more data: '
extracting c3500XL-c3h2s-mz.120-5.WC3b.bin (1751867 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!'
C2900XLFlashCli 754 {8/15/2002 10:13:25}: Flash copy is still going on ...Retry count: 0/87
C2900XLFlashCli 758 {8/15/2002 10:13:25}: Pausing for 60 seconds ...
C2900XLFlashCli 691 {8/15/2002 10:14:25}: C2900XLFlashCli::check_flash_operation_status
C2900XLFlashCli 710 {8/15/2002 10:14:25}: Processing left over data from interact_flash_operation inside check_flash_operation_status function
C2900XLFlashCli 723 {8/15/2002 10:14:25}: wait returned/left over data inside check_flash_operation_status pre-match: '' match: '
C2900XLFlashCli 1934 {8/15/2002 10:14:25}: C2900XLFlashCli::read_full_buffer_data
C2900XLFlashCli 732 {8/15/2002 10:14:29}: wait ret inside (2) check_flash_operation_status pre-match: '' match: '
extracting c3500XL-c3h2s-mz.120-5.WC3b.bin (1751867 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!' more data: '!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [Abort: End of data transfer]%rcp: Protocol error, End of data transfer
Premature end of tar file
Switch#'
C2900XLFlashCli 746 {8/15/2002 10:14:29}: Host prompt seen in check_flash_operation_status function
C2900XLFlashCli 940 {8/15/2002 10:14:29}: C2900XLFlashCli::post_flash_operation
{8/15/2002 10:14:29}: RcpSvc::rm_rhost(10.231.116.6, cwuser)
FlashCLI.pm 2006 {8/15/2002 10:14:29}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:14:29}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:14:29}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:14:29}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:14:29}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:14:33}: Device received config terminal command prematch: config terminal
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:14:33}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:14:33}: Command to send : no ip rcmd remote-user cwuser
FlashCLI.pm 2419 {8/15/2002 10:14:33}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:14:33}: Command to send : exit
FlashCLI.pm 2006 {8/15/2002 10:14:33}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:14:33}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:14:33}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:14:33}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:14:33}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:14:37}: Device received config terminal command prematch: config terminal
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:14:37}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:14:37}: Command to send : ip http server
FlashCLI.pm 2419 {8/15/2002 10:14:37}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:14:37}: Command to send : exit
TftpSvc.pm 515 {8/15/2002 10:14:37}: TftpSvc::erase_tftp_file
TftpSvc.pm 516 {8/15/2002 10:14:37}: //file_name = 'px_sw_5714_6764'//
TftpSvc.pm 281 {8/15/2002 10:14:37}: TftpSvc::get_tftp_root_directory
TftpSvc.pm 524 {8/15/2002 10:14:37}: will remove 'd:\upsdata\cw2k\CSCOpx\tftpboot/px_sw_5714_6764'
FlashFileName.p 61 {8/15/2002 10:14:37}: FlashFileName::get_flash_partition_name
FlashFileName.p 62 {8/15/2002 10:14:37}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.tar'//
C2900XLFlashCli 1649 {8/15/2002 10:14:37}: C2900XLFlashCli::get_flash_device_info flash_part_name = 'flash'
C2900XLFlashCli 1698 {8/15/2002 10:14:37}: Avail: 3149312 Used: 463360 Total:
C2900XLFlashCli 1715 {8/15/2002 10:14:37}: CRITICAL ERROR... FILE INFO --- C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMECHECKSUMundefSIZEPERMISSIONSSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: Permissions: Length:
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEc3500XL-c3h2s-mz.120-5.WC3b.binCHECKSUMundefSIZE454656PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: c3500XL-c3h2s-mz.120-5.WC3b.bin Permissions: -rwx Length: 454656
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEinfoCHECKSUMundefSIZE109PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: info Permissions: -rwx Length: 109
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEvlan.datCHECKSUMundefSIZE2664PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: vlan.dat Permissions: -rwx Length: 2664
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEinfo.verCHECKSUMundefSIZE108PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: info.ver Permissions: -rwx Length: 108
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEenv_varsCHECKSUMundefSIZE318PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: env_vars Permissions: -rwx Length: 318
C2900XLFlashCli 1734 {8/15/2002 10:14:37}: FILE INFO --- NAMEconfig.textCHECKSUMundefSIZE2600PERMISSIONS-rwxSTATUSvalidC2900XLFlashCli 1737 {8/15/2002 10:14:37}: Filename: config.text Permissions: -rwx Length: 2600
FlashFileName.p 88 {8/15/2002 10:14:37}: FlashFileName::get_base_file_name
FlashFileName.p 89 {8/15/2002 10:14:37}: //flash_file_name = 'flash:c3500XL-c3h2s-mz.120-5.WC3b.bin'//
DeviceIOS.pm 970 {8/15/2002 10:14:37}: DeviceIOS::find_flash_file_size file name: c3500XL-c3h2s-mz.120-5.WC3b.bin
DeviceIOS.pm 977 {8/15/2002 10:14:37}: Returning 454656 undef
C2900XLFlashCli 1107 {8/15/2002 10:14:37}: Source File Size: 1751867 Dst Size: 454656
C2900XLFlashCli 1112 {8/15/2002 10:14:37}: Source file size (on disk) anddst file size on flash does not match
SWDErrCode.pm 392 {8/15/2002 10:14:37}: Error returned in 'd:/upsdata/cw2k/CSCOpx/cgi-bin/swim/swd/C2900XLFlashCli.pm:1115'
SWDErrCode.pm 393 {8/15/2002 10:14:37}: Error Code: '4175'
SWDErrCode.pm 394 {8/15/2002 10:14:37}: Error Message: 'Device Error: Flash copy to/from operation failed.'
SWDErrCode.pm 395 {8/15/2002 10:14:37}: Error Action/Reason: 'Probable Cause: The source file size and the destination file size do notmatch. Disk space on tftp root directory may not be sufficient. Recommended Action: Verify disk space in the TFTP directoryand retry the operation. If the problem persists, contact your technical support representative for assistance.'
C2900XLFlashCli 1160 {8/15/2002 10:14:37}: C2900XLFlashCli::flash_operation_cleanup
C2900XLFlashCli 1165 {8/15/2002 10:14:37}: Deleting the temporary file in tftp boot directory
{8/15/2002 10:14:37}: RcpSvc::rm_rhost(10.231.116.6, cwuser)
FlashCLI.pm 2006 {8/15/2002 10:14:37}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:14:37}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:14:37}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:14:37}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:14:37}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:14:41}: Device received config terminal command prematch: config terminal
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:14:41}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:14:41}: Command to send : no ip rcmd remote-user cwuser
FlashCLI.pm 2419 {8/15/2002 10:14:41}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:14:41}: Command to send : exit
FlashCLI.pm 2006 {8/15/2002 10:14:41}: FlashCLI::change_device_config
FlashCLI.pm 2010 {8/15/2002 10:14:41}: inside change_device_config connection : IosTelnet=GLOB(0x4e793d4)
FlashCLI.pm 2396 {8/15/2002 10:14:41}: FlashCLI::print_command
FlashCLI.pm 2014 {8/15/2002 10:14:41}: config terminal command got to the device
FlashCLI.pm 2368 {8/15/2002 10:14:41}: FlashCLI::read_full_buffer_data
FlashCLI.pm 2032 {8/15/2002 10:14:45}: Device received config terminal command prematch: config terminal
Switch(config)#
FlashCLI.pm 2037 {8/15/2002 10:14:45}: Device is at config command prompt now ...
FlashCLI.pm 2042 {8/15/2002 10:14:45}: Command to send : ip http server
FlashCLI.pm 2419 {8/15/2002 10:14:46}: FlashCLI::check_telnet_error
FlashCLI.pm 2042 {8/15/2002 10:14:46}: Command to send : exit
SWDErrCode.pm 477 {8/15/2002 10:14:46}: Error propagated up in 'd:/upsdata/cw2k/CSCOpx/cgi-bin/swim/swd/SWDErrCode.pm:488'
{8/15/2002 10:14:46}: Job Result data: {8/15/2002 10:14:46}: Job Result data: Error loading image to Flash.
SWDErrCode.pm 477 {8/15/2002 10:14:46}: Error propagated up in 'd:/upsdata/cw2k/CSCOpx/cgi-bin/swim/swd/UpgradeUtil.pm:586'
SWDErrCode.pm 477 {8/15/2002 10:14:46}: Error propagated up in 'd:/upsdata/cw2k/CSCOpx/cgi-bin/swim/swd/UpgradeRFR.pm:55'
JobResults.pm 448 {8/15/2002 10:14:46}: Job Result data: Error Info Code: '4175'
JobResults.pm 448 {8/15/2002 10:14:46}: Job Result data: Message: 'Device Error: Flash copy to/from operation failed.'
JobResults.pm 448 {8/15/2002 10:14:46}: Job Result data: Action/Reason: 'Probable Cause: The source file size and the destination file size do notmatch. Disk space on tftp root directory may not be sufficient. Recommended Action: Verify disk space in the TFTP directoryand retry the operation. If the problem persists, contact your technical support representative for assistance.'
DeviceIOS.pm 686 {8/15/2002 10:14:46}: DeviceIOS::close_ios_device
{8/15/2002 10:14:46}: InitDevice::disconnect_device
SNMPsvc.pm 536 {8/15/2002 10:14:46}: SNMPsvc (disconnect) ::Printing to wh106764 : ]
SNMPsvc.pm 540 {8/15/2002 10:14:46}: SNMPsvc (disconnect) ::Reading from rh206764 : ]+
RSPFlashCli.pm 1750 {8/15/2002 10:14:46}: Closing telnet connection!
DriverUtil.pl 537 {8/15/2002 10:14:46}: DriverUtil::unlock_any_device job id: 21
DriverUtil.pl 540 {8/15/2002 10:14:46}: there is a device to unlock: 10.231.116.6 -- will unlock now
DriverUtil.pl 473 {8/15/2002 10:14:46}: DriverUtil::lock_device, device: 10.231.116.6flag: 0 job id: 21
DriverUtil.pl 481 {8/15/2002 10:14:46}: jre: d:\upsdata\cw2k\CSCOpx/bin/cwjava cli-prog: com.cisco.nm.cmf.jrm.lockcli lock-param: -u owner: Software-Image-Manager-Job-21
DriverUtil.pl 497 {8/15/2002 10:14:46}: command line: -- 'd:\upsdata\cw2k\CSCOpx/bin/cwjava com.cisco.nm.cmf.jrm.lockcli -u Software-Image-Manager-Job-21 10.231.116.6@14400 2>d:/upsdata/cw2k/CSCOpx/temp\s6jc.2' --
DriverUtil.pl 503 {8/15/2002 10:14:51}: return value from command: 0
DriverUtil.pl 511 {8/15/2002 10:14:51}: File contents:
DriverUtil.pl 527 {8/15/2002 10:14:51}: will reset last device locked to empty
{8/15/2002 10:14:51}: Job Result data: {8/15/2002 10:14:51}: Job Result data: Device has been unlocked {8/15/2002 10:14:51}: Job Result data: from exclusive access.
HistUtil.pm 770 {8/15/2002 10:14:51}: Enter format_date(1029420891)
IOSDriver.pm 865 {8/15/2002 10:14:51}: Inventory upgrade request sent for device: 10.231.116.6
IOSDriver.pm 876 {8/15/2002 10:14:55}: Device '10.231.116.6' took 646 secs for upgrade
HistUtil.pm 770 {8/15/2002 10:14:55}: Enter format_date(1029420895)
{8/15/2002 10:14:55}: Job Result data: {8/15/2002 10:14:55}: Job Result data:
{8/15/2002 10:14:55}: Job Result data: {8/15/2002 10:14:55}: Job Result data: Image Upgrade Failed
{8/15/2002 10:14:55}: Job Result data: {8/15/2002 10:14:55}: Job Result data: End Time : 15 Aug 2002 10:14:55 EDT {8/15/2002 10:14:55}: Job Result data: {8/15/2002 10:14:55}: Job Result data: Time Taken: 10 mins 46 secs
IOSDriver.pm 887 {8/15/2002 10:14:55}: Initializing database in IOSJobRecord
IOSDriver.pm 897 {8/15/2002 10:14:55}: device host name: 10.231.116.6
IOSDriver.pm 899 {8/15/2002 10:14:55}: device id: 49
IOSDriver.pm 907 {8/15/2002 10:14:55}: sql string is: SELECT sysObjectId FROM managed_dev, dev_type WHERE managed_dev.Device_Id = 49 AND managed_dev.Device_Type_Id = dev_type.Device_Type_Id
IOSDriver.pm 917 {8/15/2002 10:14:55}: Murali-Parsing going on
IOSDriver.pm 922 {8/15/2002 10:14:55}: Inside file read - 1.3.6.1.4.1.9.1.380
IOSDriver.pm 922 {8/15/2002 10:14:55}: Inside file read - 1.3.6.1.4.1.9.1.379
IOSDriver.pm 945 {8/15/2002 10:14:55}: device class: IOS
JobRecord.pm 178 {8/15/2002 10:14:55}: JobRecord::update_job_data_file //updating 'd:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswd.dat' for device class: 'IOS'//
JobRecord.pm 180 {8/15/2002 10:14:55}: Will construct back hash of device job data now
JobRecord.pm 185 {8/15/2002 10:14:55}: converting data for 10.231.116.6
JobRecord.pm 199 {8/15/2002 10:14:55}: updated the job data file'd:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswd.dat' {8/15/2002 10:14:55}: SNMPsvc.pm 415 {8/15/2002 10:14:55}: SNMPsvc (close) ::Printing to wh106764: .
SNMPsvc.pm 420 {8/15/2002 10:14:55}: SNMPsvc (close) ::Reading from rh206764: .+
{8/15/2002 10:14:55}: Job Result data: Job encountered error. Job aborted.
DriverUtil.pl 203 {8/15/2002 10:14:55}: DriverUtil::update_job_sch_status
//job_id: 21 new_status: 5 reject_comment: ''
JobAPI.pm 95 {8/15/2002 10:14:55}: Enter update_sch_job_status
HistoryLib.pm 869 {8/15/2002 10:14:55}: Enter update_sch_job_status.
HistUtil.pm 753 {8/15/2002 10:14:55}: Enter dump_hash
HistUtil.pm 756 {8/15/2002 10:14:55}: Job_Status => 5
HistUtil.pm 756 {8/15/2002 10:14:55}: Job_Id => 21
HistoryLib.pm 882 {8/15/2002 10:14:55}: BEFORE UPDATE
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Name
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Cas_Log_Id
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Status
HistoryLib.pm 887 {8/15/2002 10:14:55}: UPDATE Job_Status and 5
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Scheduled_At
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Reboot_At
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Notify_Addrs
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Type
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Schedule_Frequency
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Description
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is _Email
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is _PortNo
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Comments_By_Approver
HistoryLib.pm 885 {8/15/2002 10:14:55}: UPDATE key is Job_Approved_By
HistoryLib.pm 891 {8/15/2002 10:14:55}: AFTER UPDATE
HistUtil.pm 447 {8/15/2002 10:14:55}: Enter in_str
HistUtil.pm 448 {8/15/2002 10:14:55}: field is Job_Id
HistUtil.pm 449 {8/15/2002 10:14:55}: str is 21
HistDbUtil.pm 134 {8/15/2002 10:14:55}: Enter retrieve_rows
HistDbUtil.pm 135 {8/15/2002 10:14:55}: sql is SELECT Job_Name, Job_Parameters FROM SCHEDULED_JOB WHERE Job_Id IN ('21')
HistDbUtil.pm 140 {8/15/2002 10:14:55}: Connecting to DB
HistDbUtil.pm 161 {8/15/2002 10:14:55}: start retrieve_rows :::Thu Aug 15 10:14:55 2002:
HistDbUtil.pm 170 {8/15/2002 10:14:55}: 21,_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;,
HistDbUtil.pm 173 {8/15/2002 10:14:55}: end retrieve_rows :::Thu Aug 15 10:14:55 2002:
HistDbUtil.pm 176 {8/15/2002 10:14:55}: Disconnecting from DB
HistoryLib.pm 829 {8/15/2002 10:14:55}: Enter decode: parameters is _CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _CfgUpdate, 8000
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _Boot, 3000
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _ImgFB, 6001
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _UpdBoot, 7001
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _OnError, 4003
HistoryLib.pm 836 {8/15/2002 10:14:55}: decode _BackupCurrImg, 9001
HistoryLib.pm 929 {8/15/2002 10:14:55}: merged paramater
HistoryLib.pm 938 {8/15/2002 10:14:55}: create jobParameters
HistoryLib.pm 940 {8/15/2002 10:14:55}: _CfgUpdate => 8000
HistoryLib.pm 940 {8/15/2002 10:14:55}: _Boot => 3000
HistoryLib.pm 940 {8/15/2002 10:14:55}: _ImgFB => 6001
HistoryLib.pm 940 {8/15/2002 10:14:55}: _UpdBoot => 7001
HistoryLib.pm 940 {8/15/2002 10:14:55}: _OnError => 4003
HistoryLib.pm 940 {8/15/2002 10:14:55}: _BackupCurrImg => 9001
HistoryLib.pm 945 {8/15/2002 10:14:55}: after listing extra _CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;.
HistoryLib.pm 953 {8/15/2002 10:14:55}: string is Job_Status = '5',Updated_At = 'Thu Aug 15 10:14:55 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;'
HistoryLib.pm 964 {8/15/2002 10:14:55}: SQL command is UPDATE SCHEDULED_JOB SET Job_Status = '5',Updated_At = 'Thu Aug 15 10:14:55 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;' WHERE Job_Id IN ('21')
HistDbUtil.pm 93 {8/15/2002 10:14:55}: Enter execute_SQL
HistDbUtil.pm 94 {8/15/2002 10:14:55}: sql parameter is UPDATE SCHEDULED_JOB SET Job_Status = '5',Updated_At = 'Thu Aug 15 10:14:55 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;' WHERE Job_Id IN ('21')
JobResults.pm 79 {8/15/2002 10:14:55}: summary file: d:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswdresult.dat_summary
{8/15/2002 10:14:55}: Job Result data: JOB ID - 21 SUMMARY
{8/15/2002 10:14:55}: Job Result data: Device Name : 10.231.116.6
{8/15/2002 10:14:55}: Job Result data: Software upgrade result - Failed
{8/15/2002 10:14:55}: Job Result data: Total number of devices scheduled for upgrade: 1
{8/15/2002 10:14:55}: Job Result data: Number of devices upgraded: 0
{8/15/2002 10:14:55}: Job Result data: Number of devices failed : 1
{8/15/2002 10:14:55}: Job Result data: Total time taken for Job - 10 mins 51 secs
{8/15/2002 10:14:55}: Job Result data: -----------------------------------------------------------------
DriverUtil.pl 447 {8/15/2002 10:14:55}: DriverUtil::log_job_summary_record job start/end: 1 event mesg: Devices processed: 1, devices changed : 0, failed devices: 1
SWIMEncase.pm 50 {8/15/2002 10:14:55}: SWIMEncase::log_summary_record start/end?: 1
SWIMEncase.pm 53 {8/15/2002 10:14:55}: input event mesg passed : Devices processed: 1, devices changed : 0, failed devices: 1
SWIMEncase.pm 70 {8/15/2002 10:14:55}: details url: /cgi-bin/swim/EncaseJobDetails.pl?READ_ONLY=1
DriverUtil.pl 457 {8/15/2002 10:15:0}: DriverUtil::log_job_summary_record Job Status Job ID 21
JobAPI.pm 95 {8/15/2002 10:15:0}: Enter update_sch_job_status
HistoryLib.pm 869 {8/15/2002 10:15:0}: Enter update_sch_job_status.
HistUtil.pm 753 {8/15/2002 10:15:0}: Enter dump_hash
HistUtil.pm 756 {8/15/2002 10:15:0}: Cas_Log_Id => 4486
HistUtil.pm 756 {8/15/2002 10:15:0}: Job_Status =>
HistUtil.pm 756 {8/15/2002 10:15:0}: Job_Id => 21
HistoryLib.pm 882 {8/15/2002 10:15:0}: BEFORE UPDATE
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Name
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Cas_Log_Id
HistoryLib.pm 887 {8/15/2002 10:15:0}: UPDATE Cas_Log_Id and 4486
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Status
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Scheduled_At
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Reboot_At
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Notify_Addrs
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Type
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Schedule_Frequency
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Description
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is _Email
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is _PortNo
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Comments_By_Approver
HistoryLib.pm 885 {8/15/2002 10:15:0}: UPDATE key is Job_Approved_By
HistoryLib.pm 891 {8/15/2002 10:15:0}: AFTER UPDATE
HistUtil.pm 447 {8/15/2002 10:15:0}: Enter in_str
HistUtil.pm 448 {8/15/2002 10:15:0}: field is Job_Id
HistUtil.pm 449 {8/15/2002 10:15:0}: str is 21
HistDbUtil.pm 134 {8/15/2002 10:15:0}: Enter retrieve_rows
HistDbUtil.pm 135 {8/15/2002 10:15:0}: sql is SELECT Job_Name, Job_Parameters FROM SCHEDULED_JOB WHERE Job_Id IN ('21')
HistDbUtil.pm 140 {8/15/2002 10:15:0}: Connecting to DB
HistDbUtil.pm 161 {8/15/2002 10:15:0}: start retrieve_rows :::Thu Aug 15 10:15:00 2002:
HistDbUtil.pm 170 {8/15/2002 10:15:0}: 21,_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;,
HistDbUtil.pm 173 {8/15/2002 10:15:0}: end retrieve_rows :::Thu Aug 15 10:15:00 2002:
HistDbUtil.pm 176 {8/15/2002 10:15:0}: Disconnecting from DB
HistoryLib.pm 829 {8/15/2002 10:15:0}: Enter decode: parameters is _CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _CfgUpdate, 8000
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _Boot, 3000
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _ImgFB, 6001
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _UpdBoot, 7001
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _OnError, 4003
HistoryLib.pm 836 {8/15/2002 10:15:0}: decode _BackupCurrImg, 9001
HistoryLib.pm 929 {8/15/2002 10:15:0}: merged paramater
HistoryLib.pm 938 {8/15/2002 10:15:0}: create jobParameters
HistoryLib.pm 940 {8/15/2002 10:15:0}: _CfgUpdate => 8000
HistoryLib.pm 940 {8/15/2002 10:15:0}: _Boot => 3000
HistoryLib.pm 940 {8/15/2002 10:15:0}: _ImgFB => 6001
HistoryLib.pm 940 {8/15/2002 10:15:0}: _UpdBoot => 7001
HistoryLib.pm 940 {8/15/2002 10:15:0}: _OnError => 4003
HistoryLib.pm 940 {8/15/2002 10:15:0}: _BackupCurrImg => 9001
HistoryLib.pm 945 {8/15/2002 10:15:0}: after listing extra _CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;.
HistoryLib.pm 953 {8/15/2002 10:15:0}: string is Cas_Log_Id = '4486',Updated_At = 'Thu Aug 15 10:15:00 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;'
HistoryLib.pm 964 {8/15/2002 10:15:0}: SQL command is UPDATE SCHEDULED_JOB SET Cas_Log_Id = '4486',Updated_At = 'Thu Aug 15 10:15:00 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;' WHERE Job_Id IN ('21')
HistDbUtil.pm 93 {8/15/2002 10:15:0}: Enter execute_SQL
HistDbUtil.pm 94 {8/15/2002 10:15:0}: sql parameter is UPDATE SCHEDULED_JOB SET Cas_Log_Id = '4486',Updated_At = 'Thu Aug 15 10:15:00 2002',Job_Parameters = '_CfgUpdate=>8000;_Boot=>3000;_ImgFB=>6001;_UpdBoot=>7001;_OnError=>4003;_BackupCurrImg=>9001;' WHERE Job_Id IN ('21')
JobResults.pm 200 {8/15/2002 10:15:0}: logged end record to encase: 4486
{8/15/2002 10:15:0}: Job Result data:
End of Job
JobResults.pm 99 {8/15/2002 10:15:0}: appened summary and device results file
TftpSvc.pm 611 {8/15/2002 10:15:0}: TftpSvc::copy_file TftpSvc.pm 612 {8/15/2002 10:15:0}: //src_file_name = 'd:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswdresult.dat_summary',dst_file_name = 'd:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswdresult.dat' create_mode = ''//
TftpSvc.pm 615 {8/15/2002 10:15:0}: Copying file d:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswdresult.dat_summary => d:/upsdata/cw2k/CSCOpx/files/schedule/21/jobswdresult.dat
TftpSvc.pm 621 {8/15/2002 10:15:0}: Copied 2545 {8/15/2002 10:15:0}: Sending results to: sryu@ups.com, from: sryu@ups.com, sender: sysssr
ConfigData.pm 100 {8/15/2002 10:15:0}: Value is smtp.ismd.ups.com/.
ConfigData.pm 101 {8/15/2002 10:15:0}: Expanded Value is smtp.ismd.ups.com.
SendMail.pm 122 {8/15/2002 10:15:0}: smtp server: smtp.ismd.ups.com
SendMail.pm 126 {8/15/2002 10:15:2}: Will try to send mail (on NT) using command: 0
SWIMCompress.pm 76 {8/15/2002 10:15:2}: Entering SWIMCompress::compress_file(d:/upsdata/cw2k/CSCOpx/files/schedule/21/swim_swd.log)
SWIMCompress.pm 105 {8/15/2002 10:15:2}: {SWIMCompress::compress_file} : Compressing with the following command: 'gzip -q -f d:/upsdata/cw2k/CSCOpx/files/schedule/21/swim_swd.log'
Blue
Re: CW2kK RME 3.1 - software distribution problem
Seems like you're trying to upgrade a ".bin" image to these XL switches?. If this is correct then, RME only upgrades XL switches using the ".tar" images and will not work with ".bin" images. This true only for these XL switches.
I have tried both .tar and .bin to upgrage the 3500XL switch, both generated same error mesages. Any other suggestion or idea...
Thanks you so much for your help.....
211
