Data distribution over FEC on Catalyst 2950/3550
Does Catalyst 2950/3550 support "load sharing per packet" or round-robin algorithm for traffic distribution over FEC ?
1 ACCEPTED SOLUTION
Bronze
Re: Data distribution over FEC on Catalyst 2950/3550
I amy be wrong, but I was always under the impressions that it only did src/dst mac hash based load balancing.
Bronze
Thank you for the reply. I thought Cisco might add load-sharing per packet into FEC since there are more functionality (Ex. QoS) on 2950/3550 over 2924/3524. Your answer is very helpful.
Try this link ...
http://www.cisco.com/warp/public/cc/techno/media/lan/ether/channel/prodlit/faste_an.htm
it may be more basic than the knowledge that you are looking for, but I refer to it often when I have questions....
108
