Webcast-Catalyst9k
Data Transmission Capacity of Network Switches
How much data transmission capacity of "WS-C2924-XL 8MB" switch in terms of 'packets' & 'bytes' ?
1 REPLY
Re: Data Transmission Capacity of Network Switches
As per http://www.cisco.com/univercd/cc/td/doc/pcat/ca2900.htm#spec
the 2924 can handle 3.0 million packets-per-second forwarding rate for 64-byte packets and a 1.6 Gbps max forwarding bandwidth.
10 mbps ports can forward 14,880 pps and 100Mbps ports 148,800.
Hope that helps.
Steve
102
