ddr more than 1 number to call? Dial up
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname remote
boot system flash
enable secret 5 $1$IctH$xbPD9StJ8DdIowwFj0ht/1
username remote password 7 04490E0B003549
username cisco password 7 070C285F4D06
ip subnet-zero
no ip domain-lookup
chat-script modem "" "ATDT\T" TIMEOUT 60 CONNECT \C
modemcap entry 3com misc &FS0=1&C1&D3&H1&R2&B1
interface Ethernet0
ip address 192.168.36.250 255.255.255.0
interface Serial0
physical-layer async
description connected to 3com Lanmodem
no ip address
encapsulation ppp
dialer in-band
dialer rotary-group 1
async default routing
async mode interactive
ppp authentication pap
interface Dialer1
description connected to 3com LanModem
ip address negotiated
encapsulation ppp
dialer in-band
dialer string 7177703398 modem-script modem
dialer hold-queue 10
dialer-group 1
pulse-time 3
no cdp enable
ppp authentication pap callin
ppp pap sent-username remote password 7 0016160B0B4F0E
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.36.254
ip route 10.0.0.0 255.255.255.0 Dialer1
dialer-list 1 protocol ip permit
snmp-server engineID local 0000000902000002176303D5
snmp-server community public RO
snmp-server chassis-id JAD05330ET2
line con 0
exec-timeout 0 0
password 7 0214015604120A
login
transport input none
stopbits 1
line 1
autoselect during-login
autoselect ppp
login local
modem InOut
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
password 7 1317121F041801
login
end
remote#
1 REPLY
Re: ddr more than 1 number to call? Dial up
You can not use dialer strings to call multiple sites however you can use multiple dialer strings tocall the same site using the dialer load-threshold command. When you have multiple dialer strings it will call the first one on your list. It will only use the second dialer string if it fails or if you reach your dialer load-threshold but, in this case the second number has to dial the same site. In order to call a second different site you will have to use dialer maps instead of dialer strings.
155
