DDR on synchronous serial line - it seems, DDR not work
Dear Sir!
I've add ip route 1.1.1.2 255.255.255.255 serial0 on R1 &
ip route 1.1.1.1 255.255.255.255 serial0 On R2
Then I turned on debug ip packet detail & used extended ping to ping 1.1.1.2
from R1's s0 interface. This output show below:
IP: s=1.1.1.1 (local), d=1.1.1.2 (Serial0/1), len 100, sending
ICMP type=8, code=0
IP: s=1.1.1.1 (local), d=1.1.1.2 (Serial0/1), len 100, encapsulation fai
led
ICMP type=8, code=0.
ICMP type=8, code=0
led
ICMP type=8, code=0
led
ICMP type=8, code=0
led
IP: s=192.168.1.34 (Serial0/0), d=224.0.0.9, len 192, rcvd 2
UDP src=520, dst=520
ICMP type=8, code=0
led
Success rate is 0 percent (0/5)
R1#
What it means?
Best regards,
Nick
Re: DDR on synchronous serial line - it seems, DDR not work
It seems you are already getting good help with this.
For what its worth. The Encap fail is - the router knowns which interface to use but does not know how.
My guess is that because you are using dialer in-band BUT with no Phone # in your config. The Phycical interface is Not working as a dial interface in this case. - Perhaps by adding as Dialer interface this may get around your problem Here is a URL of a similar setup (Except its Multilink). Using Legacy Dialer Interface This should work for you -
http://www.cisco.com/warp/customer/793/access_dial/pppmultilink.html
Dear Sir!
Yes, I made sure, that DDR works on sync serial correctly,
only if 'ppp multilink' command configured on sync serial interface
Best regards,
Nick
185
