DDR on synchronous serial line - problem with reconnection
Dear Sir!
I've point-to-point link between two routers with such configuration:
R1---R2
R1:
hostname R1
username R2 password cisco
int s0
ip address 1.1.1.1 255.255.255.0
encapsulation ppp
ppp authentication chap
dialer in-band
dialer map ip 1.1.1.2 name R2 broadcast
dialer-group 1
ppp direction callout
dialer-list 1 protocol ip permit
R2:
hostname R2
username R1 password cisco
int s0
ip address 1.1.1.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer map ip 1.1.1.1 name R1 broadcast
dialer-group 1
Q1: When I no generate any traffic during some time, then DDR disconnects the call (after dialer idle-timeout = 120s default, as I suppose). After that I
can't, for example, ping 1.1.1.2 from R1 or ping 1.1.1.1 from R2.
Why DDR not make the call automatically, even though there are interesting traffic (icmp messages)?
Q2: How can I make the make DDR call manually in this example?
Best regards,
Nick
Re: DDR on synchronous serial line - problem with reconnection
Ping should re-connect the line again..If not we need to see the following debug
debug dialer
debug ppp authentication
debug ppp negotiation
now you can take the dialer map out from both the sites and just use the the static route like following
On R1
ip route 1.1.1.2 255.255.255.255 serial0
On R2
ip route 1.1.1.1 255.255.255.255 serial0
And ping it after..Router should re-connect the line..
To leave the line connected for more time, just configure "dialer idle-timeout xxx" where xxx is in seconds..
Dear Sir!
I don't know, why to add On R1
On R2
because IOS add it automatically, when I use PPP, nevertheless I did it, and ping 1.1.1.2 from R1 (for example) --> no reaction.
So, I send to you debug dialer, debug ppp authentication & debug ppp negootiation outputs, as you wish:
When I do "no shutdown" on interface Serial0 (router R2), then:
R1# debug ppp negotiation
R1#
%LINK-3-UPDOWN: Interface Serial0, changed state to up
Se0/1 PPP: Using configured call direction
Se0 PPP: Treating connection as a callout
Se0 PPP: Phase is ESTABLISHING, Active Open [0 sess, 1 load]
Se0 LCP: O CONFREQ [Closed] id 66 len 15
Se0 LCP: AuthProto CHAP (0x0305C22305)
Se0 LCP: MagicNumber 0x40330049 (0x050640330049)
Se0 LCP: I CONFREQ [REQsent] id 13 len 15
Se0 LCP: MagicNumber 0x15281E7F (0x050615281E7F)
Se0 LCP: O CONFACK [REQsent] id 13 len 15
Se0 LCP: I CONFACK [ACKsent] id 66 len 15
Se0 LCP: State is Open
Se0 PPP: Phase is AUTHENTICATING, by both [0 sess, 1 load]
Se0 CHAP: O CHALLENGE id 246 len 25 from "R1"
Se0 CHAP: I CHALLENGE id 12 len 25 from "R2"
Se0 CHAP: O RESPONSE id 12 len 25 from "R1"
Se0 CHAP: I SUCCESS id 12 len 4
Se0 CHAP: I RESPONSE id 246 len 25 from "R2"
Se0 CHAP: O SUCCESS id 246 len 4
Se0 PPP: Phase is UP [0 sess, 1 load]
Se0 IPCP: O CONFREQ [Closed] id 29 len 10
Se0 IPCP: Address 1.1.1.1 (0x030614A80141)
Se0 IPCP: I CONFREQ [REQsent] id 12 len 10
Se0 IPCP: Address 1.1.1.2 (0x030614A80142)
Se0 IPCP: O CONFACK [REQsent] id 12 len 10
Se0 IPCP: I CONFACK [ACKsent] id 29 len 10
Se0 IPCP: State is Open
Se0 IPCP: Install route to 1.1.1.2
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to up
R1#<-- & no output after dialer idle-timeout & I ping 1.1.1.2 from R1
R1# debug ppp authentication
Se0 PPP: Using configured call direction
Se0 CHAP: O CHALLENGE id 247 len 25 from "R1"
Se0 CHAP: I CHALLENGE id 13 len 25 from "R2"
Se0 CHAP: O RESPONSE id 13 len 25 from "R1"
Se0 CHAP: I SUCCESS id 13 len 4
Se0 CHAP: I RESPONSE id 247 len 25 from "R2"
Se0 CHAP: O SUCCESS id 247 len 4
R1#<--& no output after dialer idle-timeout was ended & I ping 1.1.1.2 from R1
R1#debug dialer
Se0 DDR: Dialer statechange to up
Se0 DDR: Dialer received incoming call from
Se0 DDR: dialer protocol up
p1r1#
p1r1# <-- after dialer idle-timeout
Se0 DDR: idle timeout
Se0 DDR: disconnecting call
p1r1#
Se0/1 DDR: re-enable timeout
R1 - 2621 with c2600-jk8o3s-mz.122-6.bin installed
R2 - 2611 with c2600-jk8o3s-mz.122-6.bin installed
Q: Why DDR not work at sychronous serial interface upon the whole?
Best regards,
Nick
The problem you are trying to report is "connection will not re-establised for a ping across" ..So i wnat you to test with the static host routes to see if that fix it or not..
If you don't want that then need to see what happens when you ping again after connection went down after idle-timeout..Turn on
debug ip pack detail
Let's see what you get..
145
