DDR problems
Hope someone can help, I am having problems getting DDR to work. The config is below. I have run a number of checks and if the link is lifted manually all routing etc works perfectly. If i make the specfic call that should cause the link to be lifted DEBUG DIALER PACKETS, shows IP PERMIT but nothing happens. DEBUG ISDN or BRI0 etc show no activity. The boxes (1721's)contain two frame relay links that are used to connect to HQ however for one app I want to use ISDN because of latency & cost issues. For the ip address of the server involved I have put in a static route using the ISDN link. Suggestions on whats wrong would help. I have two routers behaving this way so I think hardware is not a problem.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname type
enable secret 5 $1$D6TA$ODOpnBPZMN8pqt/ir3HXK/
enable password cisco1
username INVER password 0 ********
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Loopback0
ip address 42.42.42.42 255.255.255.255
interface BRI0
description ISDN interface
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
interface FastEthernet0
description LAN interface
ip address 57.42.31.1 255.255.128.0
speed auto
half-duplex
no cdp enable
interface Serial0
description Frame relay main interface
no ip address
ip helper-address 57.200.127.255
ip directed-broadcast
encapsulation frame-relay
no fair-queue
frame-relay lmi-type ansi
interface Serial0.16 point-to-point
description Backup PVC to HQ
bandwidth 256
ip address 57.5.42.129 255.255.255.128
ip ospf authentication-key cisco
ip ospf cost 4000
no cdp enable
frame-relay class data
frame-relay interface-dlci 16
frame-relay payload-compression packet-by-packet
interface Serial0.17 point-to-point
description Primary link to longman
bandwidth 256
ip address 57.5.42.1 255.255.255.128
no cdp enable
frame-relay interface-dlci 17
interface Dialer1
ip address 57.3.11.2 255.255.255.128
encapsulation ppp
dialer pool 1
dialer remote-name INVER
dialer string 01953714050
dialer-group 1
no cdp enable
ppp chap hostname I_type
ppp chap password 7 0452180201791B5C0616
router ospf 100
log-adjacency-changes
area 0.0.0.42 authentication
area 0.0.0.42 stub
area 0.0.0.100 authentication
area 0.0.0.100 nssa
redistribute connected metric 2000 metric-type 1 subnets
network 57.5.42.1 0.0.0.0 area 0.0.0.42
network 57.5.42.129 0.0.0.0 area 0.0.0.100
network 57.42.31.1 0.0.0.0 area 0.0.0.42
ip classless
ip route 57.200.4.18 255.255.255.255 57.3.11.1
no ip http server
map-class frame-relay data
no frame-relay adaptive-shaping
frame-relay cir 192000
frame-relay bc 192000
frame-relay be 64000
frame-relay mincir 192000
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx deny
no cdp run
snmp-server community public RO
snmp-server community private RW
snmp-server host 57.200.91.65 private
no scheduler allocate
end
Re: DDR problems
You did not specify the next hop for 57.3.11.1. With DDR this is a required step. The fact that int di1 is in the same subnet is not relevant in this case. Add a route to 57.3.11.1 like this:
ip route 57.3.11.1 255.255.255.255 dialer1
This will probably make some difference. I did not check the config extensively enough to state that this is the only issue. It will help you one step further though.
Leo
Re: DDR problems
Leo,
The next hop address i.e. the other end of the isdn link is 57.3.11.1 I however tried your suggestion but unfortunately it didn't work. I also tried altering the ip route statement to
ip route 57.200.4.18 255.255.255.255 dialer1
this didn't work either.
I have included the output of the debug commands below, firstly as is and secondly the result of the link being brought up from the far end.
type#sh debug
Dial on demand:
Dial on demand events debugging is on
Dial on demand packets debugging is on
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
ISDN:
ISDN events debugging is on
ISDN Q931 packets debugging is on
ISDN events debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
type#ping 57.200.4.18
Sending 5, 100-byte ICMP Echos to 57.200.4.18, timeout is 2 seconds:
02:41:52: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT).
02:41:54: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT).
02:41:56: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT).
02:41:58: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT).
02:42:00: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT).
Success rate is 0 percent (0/5)
type#
This is a what happens when the link is lifted manually from the other end
type#
02:44:176093659135: CCBRI_Go Fr L3 pkt (Len=25) :
02:44:171798691840: 5 1 81 90 A1 4 2 88 90 18 1 89 70 7 81 36 30 35 34 32 31 7C
2 88 90
02:44:171798691840:
02:44:171798691840: ISDN BR0: Incoming call id = 0x0002, dsl 0
02:44:176093659135: ISDN BR0: LIF_EVENT: ces/callid 1/0x2 HOST_INCOMING_CALL
02:44:171798691840: ISDN BR0: HOST_INCOMING_CALL: (non-POTS) DATA
02:44:171798691840: ISDN BR0: HOST_INCOMING_CALL: (1) call_type = DATA
02:44:171798691840: ISDN BR0: llc valid, speed 64, call type is DATA
speed:0 async:N
02:44:171798691840: ISDN BR0: HOST_INCOMING_CALL: voice_answer_data = FALSE call
type is DATA
02:44:171798691840: ISDN BR0: Event: Received a DATA call from on B1 a
t 64 Kb/s
02:44:171798691840: ISDN BR0: Event: Accepting the call id 0x2
02:44:176093659135: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
02:44:176093659135: ISDN BR0: RM returned call_type 0 resource type 0 response 2
02:44:172607289908: CCBRI_Go Fr Host InPkgInfo (Len=9) :
02:44:171798691840: 7 0 1 0 2 3 18 1 89
02:44:171798691840:
02:44:176093659135: SAM: NULL_STATE to DL_IDLE_STATE. ev=57
02:44:40: ISDN BR0: isdn_send_connect(): msg 4, call id 0x2, ces 1 bchan 0, call
type DATA
02:44:40: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
02:44:40: ISDN: get_isdn_service_state(): idb 0x80E95B24 bchan 2 is_isdn 1 Not a
Pri
02:44:171798691840: CCBRI_Go Fr Host InPkgInfo (Len=6) :
02:44:171798691840: 4 0 1 0 2 0
02:44:171798691840:
02:44:176093659136: CCBRI_Go Fr L3 pkt (Len=4) :
02:44:176093659136: F 1 81 92
02:44:176093659136:
02:44:178254754852: ISDN BR0: LIF_EVENT: ces/callid 1/0x2 HOST_CONNECT
02:44:176093659136: ISDN BR0: Event: Connected to on B1 at 64 Kb/s
02:44:41: Di1 IPCP: Install route to 57.3.11.1
02:44:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state
to up
02:44:46: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 01463 INVER
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/41/44 ms
type#
02:45:55: Di1 DDR: ip (s=57.3.11.2, d=57.200.4.18), 100 bytes, outgoing interest
ing (ip PERMIT)
ing (ip PERMIT)
ing (ip PERMIT)
ing (ip PERMIT)
ing (ip PERMIT)
type#
Silver
Re: DDR problems
Tom
What is the next hop across the dialer ?
You should be able to ping this no problem assuming you are on the same subnet .
Can you paste in debug dialer , debug ppp neg debug ppp auth , sh isdn st
Bronze
Re: DDR problems
What "specific call" are you making to try to make it call? You should be pinging the other side. I dont think the route statement is needed.
Re: DDR problems
The specific call is to 57.200.4.18 via 57.3.11.1 rather than the 57.5.42.2 on serial1/0.17 in the config. I am trying to test the link with a ping to 57.200.4.18 the results of which I've included in my answer to Leo above.
Tom
Re: DDR problems
deilert,
I have pasted the debug output in my answer to Leo, also the next hop address is 57.3.11.1.
Tom
Silver
Re: DDR problems
Tom what does the config on the remote end look like ?
Re: DDR problems
The remote end is actually a 3com NetbuilderII, however if I lift the call the link performs perfectly. The output of the debug seems to me to be saying that the DDR config is failing to lift the link or even attempting it. Any idea on how I can investigate further ?
Tom
Silver
Re: DDR problems
Tom
Is this in the US ?
If it is configure your dialer to dial your second spid as a dialer string see if it connects
Re: DDR problems
The network is spread over the north of scotland. We are not required to set spid's on isdn.
Tom
Silver
Re: DDR problems
I think I know what the problem is
when you do a sh int di 1 is the interface up (spoofing) up (spoofing) ?
If no add the command 'dialer in-band'
This will allow the dialer to go up (spoofing) up (spoofing) your router never dials out because a router will never route a packet out a down interface
Re: DDR problems
sorry the interface dialer1 is up and spoofing
Tom
Re: DDR problems
If anyone is interested I got the solution eventually, it is a software problem. I replaced the code version with 12.3 and it now works with exactly the same config.
the version of code I was using is 12.2(4)YA2 system image file c1700-y7-mz.122-4.bin
i.e. don't use this version to do DDR over isdn.
Tom
117
