debugging stp problem on C2950
hi,
I'm trying to debug an intermittent STP problem in an L2 network with a combination of C2924XL-EN and C2950-24 switches.
I see the following error:
ds-17-19.p 6483: 1y18w: %RTD-CLUSTER_MEMBER_1-1-ADDR_FLAP: FastEthernet0/1 relearning 17 addrs per min
I've found the documentation that deals with this message. I should try and trace the problem to the correct ethernetports using the 'debug ethernet-controller addr' command. This works fine on the C2924XL-EN switches, but the C2950-24 does not recognize the 'address' flag:
17.19-trunkswitch#debug ethernet-controller ?
phy Ethernet Controller PHY
stp Ethernet Controller Spanning Tree
vlan Ethernet Controller VLANs
What is the equivalent of the 'address' flag on the C2950-24 ??
thanks,
Frans
17.19-trunkswitch#sh ver
IOS (tm) C2950 Software (C2950-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 30-Apr-01 07:56 by devgoyal
Image text-base: 0x80010000, data-base: 0x8031A000
ROM: Bootstrap program is CALHOUN boot loader
17.19-trunkswitch uptime is 22 weeks, 5 days, 4 hours, 13 minutes
System restarted at 09:50:57 UTC Thu Feb 7 2002
System image file is "flash:c2950-c3h2s-mz.120-5.3.WC.1.bin"
cisco WS-C2950-24 (RC32300) processor (revision 02) with 22260K bytes of memory.
Processor board ID FAB0519Q1J6
Last reset from system-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:05:DC:CD:BA:40
Motherboard assembly number: 73-5781-08
Motherboard serial number: FAB0519A28K
Model revision number: 02
Model number: WS-C2950-24
System serial number: FAB0519Q1J6
Configuration register is 0xF
1 REPLY
Bronze
Re: debugging stp problem on C2950
Per the following link, the command should function:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/2950_wc/scg/scg_syse.htm
Ensure you are ussing 'addr' and not the full 'address' command. Also, it may be a hidden command.
162
