Decnet routing between vlans?
What is the secrete to making Decnet route between VLANs? I have 17 Vlans setup and need to route Decnet between 3 of them.
Re: Decnet routing between vlans?
It depends on IOS feature set you are running. If you have are running Enterprise plus or IP/IPX/AT/DEC you should be fine. Let me know what feature set you have currently. A sh ver should tell you this
-Prashanth
Does Cat 4006 support Decnet routing between Vlans ?
Both the SupIII and the 4232-L3 do NOT support DecNet routing.
126
