Default Confuguration to load
Hello Everyone,
I have cisco router 871 series.IT is configured with username and password.
And i dont know the password to log into Router.
I want to load the router to the default configuration.or want to erase password.
How can i do this?
Can any one give me solution for this?
Any kind help will be highly appreciated.
Bharat.
Silver
Re: Default Confuguration to load
Bharat,
Simply follow the password recovery procedure from the link below.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d284.html#wp1038210
Hope this helps
Steve
Hi Steve,
Thanks for yr reply.but in the router configuration it is not showing any registor value.
Here i am copying the details when i boot up the router.
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(6)T2, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 16-May-06 17:41 by kellythw
Image text-base: 0x8002008C, data-base: 0x81639198
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 871 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memo
ry.
Processor board ID FHK1024201T
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
%NAT: Error activating CNBAR on the interface FastEthernet4
%NAT: Error activating CNBAR on the interface Vlan1
Press RETURN to get started!
150
