Community Member
Default NPE for 7206 VXR router
Hi !
Our router defaults to NPE-175 whenever it doesn't recognize the installed NPE. Is it possible to define the NPE-type for the 7206 VXR manually ? I want to use NSE-1.
If yes, then please let me know what command to use.
Thanks.
Fareeduddin Ahmad, Network Engineer
1 REPLY
Silver
Re: Default NPE for 7206 VXR router
Fareerduddin,
No you cannot specify the NPE/NSE types for your router. Assuming you are running proper IOS to support this HW it should be recognized. I would be surprised if your router would correctly even boot if you did not have required IOS though.
HW/SW Compatability page URL for determining this:
http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi/
NSE-1 IOS Requirements:
12.1(1)E, 12.1(5)T, 12.2(1), 12.2(2)T
Hope this helps,
Don
222
