default routing for voip?
Hi all,
when I implement dialing-plan for voip, if I want to config the number that had not config to route to a target. is the command "destination-pattern *" and then "session target ipv4:x.x.x.x" enough? Moreover, Is there any commands to explict define that the number that using is e.164 or other dialing plan? Thank You!
Best Regards
Teru Lei
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: default routing for voip?
As I understand your question, you want a "voice default route"
(don't know number, length of number) to a CCM / GW / ...
You could use (just as an example)
dial-peer ....
destination-pattern [1-9]T
for all numbers not beginning with "0".
A "*" is not a wildcard, but the "*" on the dial pad!
Cheers,
Martin
1 REPLY
dial-peer ....
Cheers,
Martin
80
