Webcast-Catalyst9k
demand circuit causing problems
Folks,
Learning about demand circuit. for some reason the isdn keeps coming up. debug dialer shows that the bri interface is sending a broadcast, here is the output:
07:21:26: BR1/0 DRY: cdp, 315 bytes, outgoing uninteresting (no list matched)
07:21:26: BR1/0 DDR: sending broadcast to ip 10.10.10.5 -- failed, not connected
my question is why is the bri interface trying to send a broadcast to the other side and how do i prevent it from happening.
1 REPLY
Re: demand circuit causing problems
Do you have a dialer map in the isdn configuration. If yes, add the broadcast keyword to the dialer map.
98
